Old 05-19-2009, 04:54 PM
Jeff in north Texas Jeff in north Texas is offline
Found a Gladiator PU. What year is it? 2406F13812
I found an old Gladiator stepside pickup nearby. There is no paperwork of any kind for it and I can not figure out the year by the VIN. I looked at the VIN decoder on this site, but it is still not clear to me.
So, can someone tell me what year this is?
J200 4x4 pickup.
VIN 2406F 13812
Thanks,
1981 J10 Honcho, 360/4 spd.
Old 05-19-2009, 05:05 PM
mattmopar440's Avatar
This is all I could find
1962-1964
24=J-200 4WD Gladiator
06=Cab and Chassis-Truck
F= 4000DVW Truck
1=Left Hand Drive
91' Grand Wagoneer
401/727/229, Currently:Down for Body Work
77' Wagoneer 401 Parts rig
80's J10 258/T-5/208
89' Jeep GrandWagoneer
New Project
Inferior Chevy
Old 05-19-2009, 05:14 PM
Yes, that is as far as I could get. I was thinking maybe there is a way to narrow it down to the exact year??
Old 05-19-2009, 05:16 PM
From what i could come up with I'd say it's a 1/2 ton 64 J200 GVWR 4000lb(44's front and rear) 4WD,built in 4/64
Old 05-19-2009, 05:38 PM
Joe,
Thanks for that info. Did you figure that out from the vin decoder here, or do you have a different source to get that info from?
Thanks again.
Old 05-19-2009, 07:04 PM
Kaiser never put the year in the VIN. AMC started adding the model year to the VIN in 72.
Old 05-19-2009, 07:17 PM
Tornado230's Avatar
The build date is on the motor, however, it needs to be decoded. I have seen the info, but don't have it.
Some of the guys on Willys Tech site would have that.
This is assuming that the motor has not been replaced.
The other way would be an old NADA book, which lists the model year and serial numbers based on sales data at that time.
Old 05-20-2009, 03:29 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Pics?
Old 05-20-2009, 03:31 PM
janie's Avatar
janie janie is offline
Dexron Impaired
Jeff, you got this bad boy in your driveway yet? And yup.......................
Old 05-20-2009, 03:39 PM
I am still negotiating. There is no paperwork of any kind for the truck, so getting it on the road would be a problem. I know it can be done with a bonded title, but that is a pain to do. Trans or clutch is bad. Engine will turn by hand, but not currently running. I think the price is too high.
Did not have my camera when I went to look at it, so no photos yet. If I go look at it again, or actually buy it, I will get photos.
