Old 03-04-2021, 08:18 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
NEED HELP ~ Dual battery mount on firewall?
Has anyone mounted both batteries off the firewall where the heater box and fan were? I've been googling my arse off and haven't been able to find a mount that bolts to the firewall, even more so one that will not have issues with the Cummins 5.9l turbo set up.
I'd appreciate all of the help I can get. TIA
Originally Posted by will e
Old 03-04-2021, 08:54 PM
goldhammer's Avatar
Might look at some of the older CJ set ups. I know some people mounted two vertically back there. You could get one there and one in the stock location if it hasn't gone with the 5.9.
Probably going to have to fabricate something out of thin air in the end.
Art
ASE Master Collision Tech
Old 03-04-2021, 09:48 PM
ZacharyH ZacharyH is offline
You can cut the inside of the fender and fit 2 batteries.
Old 03-04-2021, 10:42 PM
SJTD SJTD is offline
I did the above but one on each fender. Several years ago. Sometimes I wonder why I didn't put them on the firewall as you propose, I don't think I even considered it at the time.
Sic friatur crustulum
Old 03-05-2021, 10:29 AM
Agreed.
I rolled my own? I believe 2 would fit in that spot.
Old 03-06-2021, 02:38 AM
Heep-J4000's Avatar
There are duall battery trays for the jeep cj's available.
So you could make something like that for your truck!
May I ask what kind of radiator you run with the Cummins in your jeep?
99' Dodge ram 2500 4x4 crew cab 5.9 Cummins (backup work truck for now
73' Jeep J4000 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is going to have a major overhaul
Trucks/car's from the past:
77' Mini mk1 1100 special.
Old 03-07-2021, 08:45 PM
Tigger4X's Avatar
Those are showing up a lot in my search, but none that will either fit or will mount to the firewall.
That would have been the easiest route, only needing to install a firewall mount where the heater box & squirrel cage was buuuut thats where the PO hacked the fenderwell to put the OEM Dodge filter housing.
That may end up being the case, but I'd end up having to give up a kidney to pay a shop to fab one to fit.
Old 03-07-2021, 08:48 PM
Tigger4X's Avatar
The PO hacked the inner fenderwell to put the one battery at the firewall and the Dodge OEM filter housing where your pic shows the batteries.
How do you get your pics to post? I no longer have a photo bucket and don't want to pay to host pics.
Old 03-07-2021, 08:58 PM
Tigger4X's Avatar
If I mount one on each side there are a plethora of options to mount the passenger side, width wise. There is just enough room to get a battery in between the brake booster and the hood springs, but I can't find a mount that positions the battery lengthwise from the firewall.
Old 03-07-2021, 09:05 PM
Tigger4X's Avatar
Originally Posted by babywag
Agreed.
The measurements bear out that two batteries will fit mounted length wise on the firewall, but a heat shield would be necessary because of the location of the turbo.
If I had the skills and tools or the wallet to pay a shop I would have posted it up as a tech type article so the next person has another option to choose from. It sure has me missing all of the resources I had in CA.
Old 03-08-2021, 08:31 AM
If you can find a local welding shop they are usually pretty reasonable for projects.
Old 03-08-2021, 05:16 PM
scout4bta's Avatar
scout4bta scout4bta is offline
Have you considered using only 1 Battery?
I've used a single group 31 BlueTop Optima battery on all my first gen Dodge's with 5.9L Cummins and not had any start problems.
The group 31 has 900 CCA.
1989 GW/91.5 Dodge W250 CTD flatbed/ 06 Ford Crown Vic Police Intercepter/05 Jeep Liberty Diesel.
Old 03-08-2021, 06:35 PM
goldhammer's Avatar
Tigger-. Looks like I'm about 45 miles north of you. If you can scrounge up the materials and provide accurate measurements, I'm willing to fab up what you need.
Art
Old 03-09-2021, 02:18 PM
Tigger4X's Avatar
It has one battery in it now, courtesy of the PO, and it would start it decent weather but would take its own sweet time. They're supposed to have a 2 battery set up. If I was still in AridZona like you I would probably get by OK with one that has the higher cranking amps, but here in the PNWet of Oregon it does not like one battery, especially in the cold.
Old 03-09-2021, 02:21 PM
Tigger4X's Avatar
I've had two occasions where I had to utilize a shop and they aren't as affordable as back home in SoCal. This would take more fabrication and I'd have to tow the truck to the shop for them to guarantee the fitment. If I don't and the measurements were off for any reason it falls on me. Funds are even tighter having been dealing with a work injury or I might pursue it just to get it done.
Old 03-09-2021, 02:33 PM
Tigger4X's Avatar
A wee bit o' babble ... Ive got rough dimensions so far. I also have 2 new batteries on hand, one Group 34 and one 34/78. I doubt it matters ... the OEM battery is a Group 27, but it seemed too tall and I didn't want to risk potential contact issues with the hood. The 34 and 34/78 have the same CA/CCA ratings so I went with them. Part of me was contemplating pair of Optima, but the initial cost was a bit of sticker shock. Have you ever run them up here? Are they worth the extra $$$?
I drew up some rough sketches, but don't have a way to post them here so you can see them. They're at least worth a laugh or two. Maybe buying a pre-fabbed firewall mount and making one for the driver side? Or do think it would be easier/cheaper to do the double mount for the passenger side? (That one will need a heat shield)
Old 03-09-2021, 02:50 PM
goldhammer's Avatar
Have never run optimas.
As to cost, no idea on what the prefab unit is, where it mounts or if enough room to mirror it to fit the left side since the booster and master is over there. Or if the prefab can be modified and added to, and made to secure both batteries. Depending on space left, a heat shield shouldn't be too hard.
Art
Old 03-09-2021, 04:33 PM
oregonphil oregonphil is offline
Personally, Optimas, etc.(had one) if you compare $$ for years of service, I don't think it really pays off vs. the Everstart Max or Exide Extreme. I been using those in my cars without any failures, best bang for your buck. I live on the east side of the Cascades at 4200' basically 5-6 months of cold, snow, freezing winters. I guess if you can afford them, go for it.
OregonPhil
77 SJ 401
72 Commando 304
07 Toyota Sienna
76 HD FLH
Old 03-10-2021, 12:37 PM
Tigger4X's Avatar
Hey Phil 👋 I couldn't find enough data to support the cost of Optimas either. I bought a pair of Super Start Premiums from O'Reilly. We don't get the snow or as intense cold winters like you do here in the valley so I figured I'd roll the dice and pray I get 4 years out of em at least. Originally they were $150 each, but their low price guarantee dropped them to just under $120 each to beat out Wally World.
Old 03-10-2021, 01:10 PM
https://imgur.com/
Free image hosting
charging system driving me crazy. copsXareXslow General FSJ Tech 3 01-20-2011 01:54 AM
help! jeep is dead (electrical) flying_squirrel General FSJ Tech 23 01-19-2011 09:24 AM
Smoking Wagoneer katelynrose269 General FSJ Tech 12 12-26-2010 04:21 PM
Battery Box, Brake Lines, Spare Tire Mount DONE! H Callaway General FSJ Discussion 6 07-04-2007 04:47 PM
dual battery setup? psychoticjester General FSJ Tech 1 09-08-2004 04:22 PM
