Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Old 06-26-2013, 02:51 PM
Front Shackle Reversal-bolt on kit
After listening to all the interest in regard to a front Spring Shackle Reversal (SSR) for FSJ's, I took the time to developed a bolt on kit. First, the kit replaces the front shackle with a fixed 41/2" spring mount and relocates the shackle to the rear of the spring. The additional height of the mount corrects the caster of the front axle and provides 2" of suspension lift. Second, it is 100% bolt in, no welding is required. All that's needed is basic tools to cut out the old front brackets, drive out the old rivets and bolt in the new brackets. Lastly, you can purchase rear lift blocks to level your vehicle (I have those also) to mount larger tires and experience a softer ride. You can see these and other items at http://stores.ebay.com/RockLaurence-...p2047675.l2563
This picture shows the SSR and the optional front receiver hitch.
Rear Lift Blocks and U-bolts with FSSR $259
Old 07-01-2013, 06:22 AM
Also, please visit my store http://stores.ebay.com/RockLaurence-...p2047675.l2563. I have the kits listed there along with a lot of used FSJ parts.
Old 07-01-2013, 05:24 PM
I just posted the rear lift blocks along with U-bolts. Now, you can have an affordable lift kit for $259 that doesn't require new shocks, drive shaft modifications (in most cases) or rides like a Covered Wagon from the cowboy days You can save on buying the FSSR, front receiver and rear lift blocks as a complete kit. PM on what you want.
Old 07-03-2013, 11:55 AM
pyro's Avatar
pyro pyro is offline
For reference, what size tires are on your truck in the pic?
'81 J10 Laredo 258/T176
'82 Cherokee 258/TF904
FSJNetwork Florida FSJ's Click Here!!!
Old 07-04-2013, 08:54 AM
Tires are 32" on 17 inch Hummer II wheels and the spring pack has 1 Ford Explorer leaf for 1" of lift. Also, note that it has a 2" body lift for a total of approximately 5" of lift. I want to step up to 35's soon.
Old 07-26-2013, 11:11 AM
RamJetFSJ RamJetFSJ is offline
Ive been waiting for something like this, but I already have 4" springs. Have you installed it with such yet?
I have 1" lift shackles already, so I would be getting approx 1.5" more lift, I would think. Maybe remove a spring to get it down a little?
Ben
1980 Wagoneer - Ram Jet 350, 700R4, NP208, 4" lift, 33x10.5 tires.
Old 07-26-2013, 04:26 PM
You'd gain approx' 2" of lift from the kit. Taking a leaf or two from the pac' would lower the vehicle and possibly improve (soften) the ride--both on and off road.
Old 10-17-2013, 06:46 AM
We have sold 7 FSSR kits so far! Not only that but we've sold to customers in Mexico and Canada (NAFDA)
Old 04-14-2014, 09:32 PM
jboymechanic jboymechanic is offline
I'm new to FSJ vehicles, will these kits fit my 1966 Gladiator?
Old 04-15-2014, 08:25 AM
No, the earliest FSJ had a post type mount for the springs. They will fit from '74 on.
Old 04-15-2014, 08:26 AM
I'm proud to report: 10 sets sold and we have a customer in Germany.
Old 07-19-2014, 07:53 AM
In regard to the install and other changes, no other changes are required for normal driving. The original shocks etc will limit wheel travel preventing issues with steering clearance and the front drive shaft. However, to maximize the potential of the FSSR you can add longer shocks and dropped bump-stops. Which allows the front axle to droop more and will require a longer splined front drive shaft and extended brake lines. The FSSR is intended to provide a moderate lift with greater ride comfort but is also the beginning of a PERFORMANCE suspension. Lastly, you will need Red thread locker, cut off tools, 1.25" hole saw, drill and other tools for the install.
RockLaurence VAP has sold 16 FSSR kits and now has customers in Germany and Brazil!
Old 08-28-2014, 12:47 PM
Dave's Avatar
Dave Dave is offline
Hello, i am new here & have a 75 wagon i am going to restore. I was wondering if your lift would work on this year?
Thanks,
Dave
Old 08-28-2014, 07:47 PM
Thanks,
Dave
Yes, it will fit on '74 and later. Sold 16 kits--customers in Australia, Mexico, Germany, Canada!!
Old 10-01-2015, 06:30 AM
33 Units SOLD and now built with 1/4" plate!
Thanks guys for your support!!
Old 12-13-2016, 07:59 AM
We SOLD unit #40 this week! We are Temporarily out of stock.
Old 12-27-2016, 09:53 AM
Out until when?
Old 12-27-2016, 12:21 PM
InternationalMarineBrian's Avatar
InternationalMarineBrian InternationalMarineBrian is offline
Just after New Years is what I recall.
Old 01-28-2017, 08:27 AM
Well?
Old 03-01-2017, 01:39 PM
Jeep Hero's Avatar
Jeep Hero Jeep Hero is offline
Question FSSR Complete Kit
Rocklaurence,
Sent you a PM a couple of days ago asking about ordering a complete kit.
JeepHero
1980 Jeep Cherokee Laredo
1979 Jeep Cherokee Chief
1981 Jeep J20
1977 Jeep Cherokee S Wide Track (Rusty Blue) (newly acquired)
J3000 shackle reversal Scuba66J3000 Off-Road FSJ Tech 18 02-17-2007 08:53 AM
Front Shackle Question/Theory Gambler68 General FSJ Tech 13 01-29-2007 07:21 PM
Stuck shackle bolt - any tips? JP General FSJ Tech 11 04-18-2005 03:19 AM
(TOM) Spring replacement lifts Sitting Bull Suspension and Steering 0 10-02-2001 02:06 PM
Front Shackle Reversal? 88GW General FSJ Tech 1 06-02-2001 06:19 AM
