Old 05-03-2013, 08:09 PM
EasTXJEEPER EasTXJEEPER is offline
NP229 Output yoke seal?
Before I get into changing out this leaky seal, do I have the right new one? Is a National #3946 the correct seal?
Are there any other suprizes awaiting me beside removing the nut and yoke and digging out the old seal. Replacing seal appears to be pretty straight forward but some threads on the subject mention a felt washer somewhere in the works.
Jeep is my 83 Cherokee Laredo with Selec-Trac. When I topped off the TC with ATF the leaky seal became very obvious.
Old 05-04-2013, 06:41 PM
Yes.
Old 02-25-2021, 11:15 AM
acct21's Avatar
acct21 acct21 is offline
I know this is a necrothread, but since it kept coming up in my search for the seals mentioned, thought I'd update it for future reference. BJ's Off Road currently offers the yoke nut seal as the "seal washer" -- #52 on the exploded drawing.
The splined washer fits inside the yoke, and once the yoke nut is tightened down this stops the oozing from the yoke. Recommend a thin application of Ultra Black over the top of this, letting it skin over before tightening down the yoke nut.
Crown J8130815
Old 02-25-2021, 07:51 PM
TomJ TomJ is offline
Crown J8130815
Those are hard as hens teeth to find. I used to have a half-dozen in a DIY box, not any more. And they're either "unavailable" or "can be ordered" for you. I just use ultra black at the end of the splines and under the nut. Never had an issue with seepage since. If you can find these, by all means, use, but...
Old 02-26-2021, 08:23 AM
J20 project's Avatar
I gave you that number on facebook right? A great resource for many folks is National Drivetrain.com....One thing you will see though is that the np229 has a very limited parts list, meaning many things are not sourced well and or available as compared to the NP 208 which I suggested.
Real straight forward on the seal swap. Best practices have you lightly sanding the yokes' seal surface and using rtv on the splines and thread lock on the nut when going back together.
J20 project
BP Drivetrain...........
775-537-7918
Old 03-05-2021, 01:00 AM
acct21's Avatar
Summit Racing had them in stock. So did BJ's. I bought mine from Summit because I needed some unrelated stuff from them. It arrived, and I installed with with a thin smear of the 'transfer case' green-tube Permatex. All buttoned up, refilled, test driven... and no leaks.
NP 229 Front Output Shaft Seal CommanderChaos General FSJ Tech 0 08-20-2012 10:53 AM
Replacing NP 229 front output shaft seal FSJ Guy General FSJ Tech 7 07-22-2009 07:23 PM
QT rear output shaft seal (now just favorite seal removal/ install techniques?) Gawdzilla. General FSJ Tech 25 08-06-2007 07:44 PM
AMC/Jeep Manual Transmission Info James 007 General FSJ Tech 0 09-02-2002 07:40 AM
D208 Output yoke source BOONIERAT General FSJ Tech 3 02-10-2002 03:37 AM
