Old 03-11-2012, 11:39 AM
pb's Avatar
pb pb is offline
No power, can't get out of it's way after sitting 5 years
HI, it's been awhile. Anyway, about five years ago, I pulled the engine out of the Wagon to replace bearings. I capped the transmission cooling hoses and vacuum lines. Long story short I did it when I started a new job and the jeep sat for years as I was busy with work and kids. I finally got the engine in and it runs fine when in park.
When I put it in gear it barely wants to move. I give it gas and it acts like it is bogging down. I do have fuel injection and it is throwing no errors. Tranny fluid is full. I haven't checked the QT fluid yet. it does roll fine as I have pushed it in neutral
Any ideas what to check? Thanks.
Paul
1975 Wagoneer DD
Old 03-11-2012, 12:20 PM
litlmeck's Avatar
litlmeck litlmeck is offline
Breaks dragging
45 GPW 231 t18 D20 44 30 (in progress)
98 TJ 2.5 5 sp 231 35 30 (Sold)
77 Wag 401 TH400 D20 60 44(Sold)
87 Wag - new project/DD
Old 03-11-2012, 02:55 PM
Rich88's Avatar
Rich88 Rich88 is offline
Hope its not this...
Clogged TBI injectors? If it sat that long the gas left in the injectors probably turned to varnish or gel. You may be getting a fraction of the gas it needs.
The right way to put an engine away for a long time that you hope to start someday is to put some stabil in the gas and run 'er until she runs out of gas. Or better yet, remove carb or TBI together and empty of gas, dry it out and seal it in a baggy.
Old 03-11-2012, 03:12 PM
pb's Avatar
pb pb is offline
I did run stabil thru it before I took the engine out. One of the injectors is brand new as I broke a post on one of them.
If it were the brakes seized up, would I not be able to push it in neutral?
I should add that it will creep along if I barely accelerate on the street, but any sort of incline it takes for ever to get up it
Paul
1975 Wagoneer DD
Old 03-11-2012, 03:14 PM
Rich88's Avatar
Check fuel pressure.
Old 03-11-2012, 03:46 PM
Plugged exhaust? Mouse/rodent house, or hooligan stuffed some stuff in the tailpipes?
Hook up a vacuum gauge, might tell you something?
Old 03-11-2012, 05:31 PM
Rich88's Avatar
That too. Vacuum knows all....tells all
Power Valve kevinator General FSJ Tech 14 10-15-2011 07:17 PM
Power Valve question and is this a vac line? slukev General FSJ Tech 20 10-14-2011 08:10 PM
2150 WOT power tapers off Rich88 General FSJ Tech 1 04-06-2011 06:39 PM
Power steering pump OR Steering box??? HOOT General FSJ Tech 6 11-27-2009 10:52 PM
Three years of annoyance- Please help Jowersgd General FSJ Tech 18 05-18-2004 05:13 PM
