Old 02-19-2010, 11:56 AM
lost1's Avatar
lost1 lost1 is offline
grr... noob question on upper ball joints
So there I am happily wrenching away, getting the rig ready for new shocks and ball joints... then I run into the first obstacle.
The circled part looks like it needs a special tool to remove it, which I don't have. And before I go stumbling into the parts store looking dazed and confused...
What sort of tool do I need?
And while I'm at it, are there any tips for removing these ball joints that are different from newer vehicles?
I've done this before on a 2000 Dodge Dakota, and those were riveted on. I see how these attach and it looks pretty straightforward, but... we know where assuming gets us.
Originally Posted by Locked and Loaded
Jeeps don't get stuck. People do.
Let the good times roll!
'83 Wagoneer«» 401/TF727/3:31 AMC20
Old 02-19-2010, 01:05 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
The tool you are looking for is called a balljoint spanner wrench and a pic of it can be found here; http://www.matcotools.com/Catalog/to...select=&page=1
The ball joints are pressed in and you will need a ball joint press tool, you can rent one at the typical mcparts store. Where you will more then likely find the spanner wrench as well.
Originally posted by Ristow
i bet it was Simon....
Old 02-19-2010, 01:37 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
Parts store will have the adjuster socket you need.
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 02-19-2010, 02:06 PM
lost1's Avatar
Many thanks fellas. Off I go!
