Old 09-26-2014, 07:56 PM
Ronburgundy Ronburgundy is offline
Noob!
tranny rebuild advice please
Hi folks, I'm fairly new to the forums. I have a stock 91 GW. I need to rebuild the tranny. It's a daily driver that I use for ready trails and camping, nothing extreme. I read Ristows rebuild thread which was very helpful. I'm not finding any listings on the tci rebuild kit for the year of my vehicle.
Does anyone have recommendations for rebuild kits and torque converter for my 91 GW?
Thanks
Old 09-26-2014, 08:01 PM
http://www.summitracing.com/parts/tci-128905/overview/
i dunno why they stop at 1979 on the app list. it's the correct kit thru the end of the 727 run.
Old 09-26-2014, 09:31 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Is this something that can be done if one has a fairly decent tool set?
are there instructional dvd's one can buy? I need to have mine done mostly because of leaks and i took a tranny apart when i was a teenager and it was a scary selection of parts....
trip
Abort? Retry? Ignore? >
Old 09-26-2014, 09:44 PM
Noob!
Thanks Ristow, any suggestions on bands and a torque converter?
Old 09-26-2014, 09:56 PM
Noob!
Tripwire, I'll let you know. I've never done this before but I've watched some YouTube videos and I have the tf 727 manual on pdf. Plus Ristow has a great write up. If you want the manual send me your email address.
Old 09-26-2014, 10:51 PM
yeah,you can do it with ordinary tools. you will need a beefy circlip pliers tho.
that kit should have the front band,i believe summit is wrong saying the band is not included,it has been included in the kits i got.
Old 09-27-2014, 06:27 AM
cst756's Avatar
cst756 cst756 is offline
Ristow is this the kit you use for the rebuild you posted here?
1983 Wagoneer
360/727/229
Running good!!!
Old 09-27-2014, 05:45 PM
i think so. tci re-named the kits a while back,i think the truck master became the maximizer.
Old 10-02-2014, 09:42 AM
del's Avatar
del del is offline
rebuild
I rebuilt my 727 a couple of months ago. Best advise was from Rich (Woodchomper) which was to buy a bunch of large freezer bags. Label every little part on bag with a marker. Also get a rebuild manual. There is a manly snapring on the output shaft, that Risto mentions above, that will laugh at a regular set of snapring pliers, so plan to get a really good set....Del
1987 Wagoneer
4" BDS Springs, 31"x10.50's
401/727/229
Old 10-02-2014, 04:09 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
trip
There is a book on the TF727 by Carl Munroe, I highly recomend it. It tells you how it works, it tells you how to rebuild each component, it tells you how to modify it.
Worth the money in my opinion.
http://www.themotorbookstore.com/torqueflite-transmission.html?cmp=googleproducts&kw=torqueflit e-transmission&gclid=CKLNksz9jsECFSMLMgodQEMA1g
WH
Herbina 1987 Grand Wagoneer
Old 10-02-2014, 04:45 PM
del's Avatar
del del is offline
book
Carl Monroe's book is what I used to rebuild mine. Read it thru before I even touched the trans
1987 Wagoneer
401/727/229
Tranny Advice Pati Wagon General FSJ Tech 1 11-02-2010 02:11 AM
tranny rebuild tools? shadowjeep General FSJ Tech 8 11-11-2007 04:30 PM
Tranny rebuild? unclebuck General FSJ Tech 2 12-14-2006 03:54 PM
What comes in the ideal tranny rebuild kit? jode General FSJ Tech 6 02-09-2004 10:56 AM
Tranny rebuild FSJ Thing General FSJ Tech 2 09-04-2003 08:17 AM
