Old 10-24-2010, 03:46 PM
icedgotti's Avatar
icedgotti icedgotti is offline
Drive shaft with 6 inch lift
I have a six inch lift on my WG and have a bad shake at low speed. Someone says I probably have a unbalanced shaft. Should I get a high angle drive shaft with a six inch lift?
1988 Burgundy Waggy named Garthok
6 inch Rough Country Lift, 35's.
3 inch body lift. Oh Christ where are you floor pans at....
Old 10-24-2010, 05:01 PM
v10sport's Avatar
v10sport v10sport is offline
Also could be bad pinion angle
77 J20
09 Rubicon Unlimited
10 Challenger SRT 8 6 Speed
11 Grand Cherokee Overland
Wisconsin Speed and Performance
Old 10-24-2010, 05:23 PM
Probly just want to change your ujoints, theyve been at one angle for who knows how many years and now theyre at a very different angle
-Jonny B.
D20 - Twin Stick'd
F D44 - 4.10, Eaton E-Locker
R D44 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 10-25-2010, 02:02 AM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
IMHO u-joints need replaced. IF you didnt compensate your lift by changing the pinion angle you need to.
Originally Posted by will e
Old 10-28-2010, 03:35 PM
icedgotti's Avatar
Well I replaced the u joints and had the drive shaft balanced. I still have the vibration at low speed any thoughts? Im starting to think its the motor not running right. Also when I was trying to see what was wrong mhy back driver brake doesnt work at all so now I have that to mess with to.
Old 10-28-2010, 03:59 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Get some manual lockout hubs. That way you can just stop the front driveline from spinning...
Do you have an angle finder? If so what angle is your shaft at?
Old 10-28-2010, 04:01 PM
Dmntxn77's Avatar
Hey watch this...
Oh wait... Do you have the crappy QT? If so Im gonna guess that they have a VC. If so, I dont think you can put manual hubs on it...
I dont know much about QT's though. Other than that they suck and all of them Ive had break...
BTW, opinions vary on that case so dont take it to heart...
Old 10-28-2010, 04:02 PM
bg2pres's Avatar
bg2pres bg2pres is offline
I agree. I have stock setup with 6" lift and put a wedge under the springs for pinion angle, but I do have a very small vibration at 20mph, but its not anything major at all.
If you are having major vibrations, do the rest of the checks the others have mentioned, but with a degree wedge, you shouldn't have major issues.
bg2pres
1979 Jeep Cherokee Golden Eagle
1990 Jeep Grand Wagoneer
2012 Jeep Wrangler Unlimited
1981 Jeep Scrambler Laredo CJ8 (sold)
2000 Jeep Wrangle TJ Sahara (sold)
Old 10-28-2010, 04:34 PM
icedgotti's Avatar
Yep wedge was applied. I have lockouts and no QT, someone just suggested the front drive axel u joints. Does that make sense to anyone. If so I guess I'll start digging into that part. I put the rear on stands and let it run and no vibrations so it may be in the front.
Old 10-28-2010, 04:43 PM
Dmntxn77's Avatar
Hey watch this...
If you already have lock outs and you still have vibration with them unlocked, then its not the front shaft. It shouldnt even be spinning while driving.
But yeah, its always a good idea to replace the old factory U-joints.
Old 10-28-2010, 07:46 PM
CutterN55's Avatar
Is this a new lift? Here's a few things I would check:
-I'd check the torque on all the bolts and take a look at the bushings.
-Lug nuts all tight?
-Maybe you threw a weight or maybe have a flat spot on one of the tires.
-try rotating your tires front to back in an "X" and see if anything changes or feels different.
Where is the vibe felt? I noticed I had a lot of vibes in the column when my caster was out.
-With the U-joints, it would be a good idea to make sure you have new ones all around anyway. And get a couple spares as a precaution to keep in your tool bag.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 10-28-2010, 07:57 PM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
Here we go again, lol
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 10-28-2010, 08:29 PM
icedgotti's Avatar
If my engine was not running right or missing out it shake like that? I cant really tell where the shake is coming from. Its not in the steering wheel. We both u joints on rear drive shaft. If i roll down hill with my foot off it rolls smooth then when i hit the gas all hell breaks loose. Sorry Im trying to trouble shoot in between posts. Ill PO'ed at the whole thing so I'm quiting for the night. Maybe tomorrow will be a better day. BTW thank you everyone for helping me its greatly appreciated.
Old 10-28-2010, 08:39 PM
CutterN55's Avatar
I don't think an engine issue would make your truck shudder that much to where "all hell breaks loose". You'd know it if you rev it in park. Do your front wheels shake side to side when you feel it? Is this a "vibe" or an "Oh crap I'm gonna crash" death wobble?
ROMANS 12:1-2
'89 GW deceased
Old 10-28-2010, 08:53 PM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
Front axle u-joints will not cause your problem. What changes did you make to your rear driveshaft?
There is no reason to change a u-joint because it's old. Maybe piece of mind...? You're wasting money if they're in good working order.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 10-28-2010, 08:58 PM
CutterN55's Avatar
I was thinking rear shaft too Casey but he said he put the rear up on stands and no vibes.
ROMANS 12:1-2
'89 GW deceased
Old 10-28-2010, 09:04 PM
Casey's Avatar
Jeep Polygamist
It will act differently with a load.
1994 YJ
1986 Comanche
'57 FC-150
www.cfsjc.com
Old 10-28-2010, 09:06 PM
Dmntxn77's Avatar
Hey watch this...
Your right, there is no reason to replace a perfectly good part...
Of course, you would have to take them out to know if they are in-fact a perfectly good part...
Personally though, I like to carry a spare and Im not going to buy a new one to keep in my rig. Instead, I will replace the old one, and carry that one as a spare.
Maybe its a waste of time, but hey, to each their own...
Old 10-28-2010, 09:09 PM
Dmntxn77's Avatar
Hey watch this...
BTW, regardless what you do with your U-joints, I really doubt this problem is being caused by one...
What kind of tires are you running?
Old 10-28-2010, 09:15 PM
Casey's Avatar
Jeep Polygamist
I carry spares. New ones.
Tires are also top on the list of things to check.
1994 YJ
1986 Comanche
'57 FC-150
www.cfsjc.com
question about front drive shaft Chief Gunner General FSJ Tech 0 12-13-2009 12:10 AM
Six inch lift noise Mudd27 General FSJ Tech 1 03-30-2008 04:13 PM
Front Drive shaft Subic Jeep Off-Road FSJ Tech 18 03-18-2008 09:05 PM
??????6 inch ttl fabworks lift jeeprunner81 Off-Road FSJ Tech 7 06-25-2007 01:37 PM
front drive shaft length with 6" lift and T18a. Stuka Off-Road FSJ Tech 21 09-27-2003 02:50 PM
