Old 07-17-2006, 03:05 PM
theJ10 theJ10 is offline
Replace the distribitor
Have a 71 J 10,or J2000 cant tell the dif?. Anyhow wanting to replace the stock points distribitor for a updated unit.Do i replace it with a new ford dist, or mopar?, or are there any suggestions for me and if I replace it what would be the wiring be? thanks for all your help
Old 07-17-2006, 04:13 PM
Menace's Avatar
Menace Menace is offline
What engine is in your truck?
Old 07-17-2006, 04:38 PM
supercopjason's Avatar
supercopjason supercopjason is offline
you have 2 major choices. HEI or pertronix!
Pertronix uses stock everything just replaces your points with a magnetic pick-up. Hei is a lot better but a little more than double the price and will need plugs and new wires.
New Addition: 1982 Cherokee W/T
Engine: AMC 360 w/ Edel intake, 1.6 rockers, Class III cam, Comp pushrods, Holley truck avenger carb, headman headers, custom built exhaust
Suspension: 6" Lift 1" shackles up front
Axles: D44/AMC 20 w/4.88 and detroits
1985 Grand Wagoneer 360/727/229
TFI upgrade, 70k orginal miles will trade for the right j-truck.
Old 07-18-2006, 08:42 AM
J4GRAND's Avatar
J4GRAND J4GRAND is offline
J4000 Restoration Specialist
I agree with supercopjason- go with a Pertronix unit. Simple replacement of the points and not too much $$$. I did the distributor in my J4000 5 years ago and haven't touched it since.
Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT
05 Jeep Grand Cherokee 3.7 V6 5 speed automatic with new QT
