Old 02-19-2019, 08:40 AM
Zorm's Avatar
Zorm Zorm is offline
maybe sacrilege question, but I've done that before
Ok, Im ready to get flamed.
How hard would it be to put a M-715 body on a 78 Cherokee Chief frame. I am already thinking of cutting sections out of the bed to shorten it, and the rear of the cab / front of the bed to have a kinda "walk through" for a rear seat.
thoughts? even pics would be cool with any modified M-715 in em.
83 Cherokee 4dr WT(axles)
4" lift, 351w in the works
78 Cherokee Chief 304
07 Sea Ray 205
71 F-250 Camper Special 390
HE guides my path, forgives me when I stray and lights my life.
Old 02-19-2019, 02:36 PM
I am doing something similar but I am using a J truck cab. My cab is a direct bolt on to the frame. If your frame is from a Chief it is probably made after 1975 and probably won't bolt direct to the M715 cab.
You can look at my build thread in my signature below for a look at what I have done so far.
Resistance is not futile yet.
Old 02-21-2019, 12:02 PM
I thought you were doing a convertible Cherokee....? plans change or are you thinking of another rig?
79 Cherokee Chief
Old 02-21-2019, 10:25 PM
Zorm's Avatar
the Cherokee body may go on a different frame still a convertible. Still looking at either a Modified Sout II soft top or modified Wrangler Unlimited soft top.
I have always like the M-715 and found one for a reasonable price.
07 Sea Ray 205
Old 03-01-2019, 10:05 AM
There are pictures of a J10 cab with short bed on Wagoneer frame on IFSJA. This is what my next Trail Jeep is going to built on. I also like the idea of M715 but with J10 cab to eliminate the front windsheild/rag top of the M715. How about this--In Mississippi I saw two short Cherokees that had the 24" behind the doors cut out making it a short wheel base Cherokee back in 1983. I havent seen one since.
Another A/C Question: York or Sanden The PIG Smith General FSJ Tech 27 07-03-2018 04:29 PM
Axle Question Jjkage84 General FSJ Tech 4 05-12-2014 11:22 PM
1 PS question, 1 eletrical question SamW General FSJ Tech 2 01-15-2011 12:31 PM
Quick 85 Grand Wagoneer Question WagoneerMan General FSJ Tech 3 01-31-2010 11:06 PM
