Old 02-02-2019, 06:25 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Awsome battery terminal connectors
https://www.amazon.com/InstallGear-P...2F10+Gauge+AWG
Bought one set to have a look, well made - however you need 4 different allen wrenches to install - a mix of metric and SAE. the only item of concern is the thread machining for the screws is ever so slightly loose so i used a low strength locker to ensure they stay put
the negative terminal is slightly smaller as it should be
Abort? Retry? Ignore? >
Old 02-02-2019, 07:52 PM
DarkMonohue's Avatar
Shakes hands with danger
Interesting. I've used this style for many years now:
https://www.amazon.com/UTSAUTO-Thick.../dp/B0787NPBFN
I like these because they allow for rapid, tool-less disconnection, and as I don't tend to have a lot of accessories that need to be wired directly to the battery, the lack of secondary connection points isn't really an issue.
Old 02-02-2019, 11:00 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Trip, I have a set (sourced locally) of very similar terminal blocks I'll be using when i do my complete harness rebuild in the near future. I have all the pieces (I think), just need to time to put it all together. I like that they have two major spots for alternator and starter.
aa
Old 02-03-2019, 05:19 AM
I use those too they work very well.
Don't like open copper connections or unsoldered with humidity here bare copper is an invitation to green invasion.
Old 02-03-2019, 08:15 AM
JeepsAndGuns's Avatar
I agree. While those terminals are a neat idea, they are not water/corrosion resistant. Moisture will get it's way into the ends of the wires and start corroding them, then start wicking down the cable under the insulation, which will eventually ruin a cable.
I prefer the military style terminals.
https://www.amazon.com/dp/B07J2FS5ZQ..._t3_B00X36RILW
That way you can use ring terminals, crimped and soldered, then covered in heat shrink tubing for a water tight seal.
Old 02-03-2019, 09:28 AM
go get new stainless set screws at the hardware store for them.
Old 02-03-2019, 10:43 AM
bkilby's Avatar
bkilby bkilby is offline
I use (and sell) the Milspec terminals in that link. They're great terminals. Funny part is their pic shows two positive terminals. Lol. I don't have the covers though.
Old 02-03-2019, 12:08 PM
Cecil14's Avatar
...Don't like open copper connections or unsoldered with humidity here bare copper is an invitation to green invasion.
Easy enough to tin the wires. I would never leave something that large and important bare wire.
aa
Old 02-03-2019, 12:51 PM
I would modify it.
Solder in the 10 and probably the 8 gauge too. Almost permanent.
Make some slots on top of the Allen screws so a screwdriver would fit so I wouldn’t have to find Allen wrenches.
It’s nice to have a couple open connectors for acc.
Old 02-03-2019, 01:12 PM
Cecil14's Avatar
I bet if you looked around, you could find philips style set screws that size.
aa
Old 02-03-2019, 01:43 PM
Phillips are easier to find tools for, but since they are designed to cam out when a certain torque figure is achieved, they would probably be my last choice for this application.
Translation: I like Phillips-head fasteners about as much as I like a good chest cold.
Old 02-04-2019, 05:37 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
No.
Acid, dirt, water, and oxygen will get into the end of the wire where it clamps into the terminal and corrode both ther terminal and the wire. It'll build up resistance there and then you'll wonder why your starter drags on cold days. Starters are such high current devices that only a small amount of resistance in their power supply will cause a significant drop in voltage and power output.
1. Crimp
2. Solder
3. Adhesive-lined heat shrink.
All three. In that order.
Old 02-04-2019, 09:43 AM
Dielectric grease is your friend.
Old 02-04-2019, 06:21 PM
Tripwire's Avatar
that is exactly what i would have said i got lucky and collected a few toothpaste tube size tubes full of it....used it on X raymachines previously
steve
Old 02-05-2019, 09:58 PM
scout4bta's Avatar
scout4bta scout4bta is offline
These terminals show the correct pair and not all the other stuff you probably don't need.
Found, the perfect Wagoneer to Dieselize, 1989 GW 360, 727, NP208
1980 IH Scout/4BTA/NV4500/Atlas 4.3/DYNO:172(HP),432(ft-lbs)25mpg
Old 02-21-2019, 01:59 AM
axton36 axton36 is offline
I also have the military-style battery terminal that I bought on amazon.
Ammeter and protection Joe Guilbeau General FSJ Tech 33 05-01-2017 01:53 PM
What could be killing my alternator? 1972 FSJ 1cdccop General FSJ Tech 25 12-17-2010 08:50 AM
Voltage Low msbiofuels General FSJ Tech 7 10-15-2010 10:08 PM
Side Terminal Battery Question (non-FSJ) mahlmann General FSJ Tech 8 12-29-2000 11:23 AM
