Old 04-05-2018, 11:41 PM
Sharps Shooter's Avatar
Sharps Shooter Sharps Shooter is offline
Killing my 304
Hey FSJeepers.
Been a long time since I was active here. Life got in the way. Been back to working on my J10. Got it running, but it's dying at random. Usually when I begin to decelerate. Once this begins, it's a 6,000 lb thorn in my side to get it going again. It restarts quick, but I'm killing it every time I engage the transmission. Any suggestions on what I'm missin?
Thank Y'all
Update.... Think I found the problem. If not,... It's still a potential problem to be addressed. A possible crack in my intake manifold, behind the carburetor.
BUMP IT, or JUMP IT!!!. Either Way, Yer Goin Through!!!
Old 04-06-2018, 09:53 AM
J20 project's Avatar
First thought, big ass vacuum leak.
J20
BP Drivetrain...........
775-537-7918
Old 04-06-2018, 09:57 AM
That'd be my first guess. Huge vacuum leak causing a severe lean condition.
Old 04-06-2018, 10:20 AM
Thanks guys. I thought I got all the hoses replaced a couple years ago, but that makes sense. Might have had something come loose in that time.
Old 04-09-2018, 02:38 PM
Make sure your Brake Booster holds vacuum. sometimes they fail internally and cause a ginormous vacuum leak.
79 Cherokee Chief
Old 04-09-2018, 02:56 PM
That was the last thing on my list. I'm gonna be checking it when the weather clears. Hoping I can get it done soon.
Thank you.
Killing power to tailgate PaulD General FSJ Tech 5 07-20-2017 10:59 AM
Gauge Cluster wiring is killing me. ThaCrabapple General FSJ Tech 18 03-27-2014 07:35 AM
Texas heat killing my Jeep GW DotJumper General FSJ Tech 26 07-10-2012 05:36 AM
Killing my battery 1990XJFSJ General FSJ Tech 3 07-17-2009 04:08 PM
Vexing electrical problem killing my battery Thomas DeBusk General FSJ Tech 4 10-31-2001 03:55 PM
