Old 03-31-2018, 12:43 PM
mwood65's Avatar
mwood65 mwood65 is offline
U joint woes....
I am having problems finding the correct U joint and hoped you guys could help. I have searched and read many posts on here but can't find the answer.
It's for my 1974 Cherokee, 4.2L, T-18, Dana 20 case.
I am looking for the REAR joint on the REAR driveshaft.
The one that came off of it (original one??) has 2 inside clips & 2 outside clips on the U joint. All the replacement ones have either 4 inside clips or 4 outside clips.......
Can't seem to find the correct one.
Old 03-31-2018, 01:04 PM
Iirc the spicer brand ones I bought had like 8 different ones included.
Old 03-31-2018, 01:11 PM
mwood65's Avatar
They had 8 different what....snap rings? The grooves on the cups have to be different also
Old 03-31-2018, 01:52 PM
I've never seen a u-joint that used 4 clips???
Possibly you're overthinking this? If there is room/groove for normal setup of 2 outside clips, install a new joint and be done with it.
Old 04-01-2018, 05:35 PM
J20 project's Avatar
Well, if you and I take this offline and discuss accurate measurements...we will figure it out.
This is what I do.
J20 project
BP Drivetrain...........
775-537-7918
Old 04-01-2018, 06:20 PM
77Deepj20 77Deepj20 is offline
I've never run ntto that type of conversion joint, but they exsist and are available.
You would have to measure the diameter of the caps and the length of the joint in both directions, then match that to the appropriate conversion u joint.
1977 j20. Dana 60's, 4:10's Chrysler 360/np435/NWF blackbox/np203
Hummer military 24 bolt wheels and 37" mt/r's.
Old 04-02-2018, 09:24 AM
sizes....
Likely this but gotta have measurements.
Bud
775-537-7918
Rag joint questions chazer General FSJ Tech 8 04-14-2012 12:26 PM
Ball Joint Issue Suddendeath General FSJ Tech 9 04-01-2012 01:01 PM
Front axel woe's, u joint FUBAR'd Rider99XX General FSJ Tech 1 08-22-2010 01:38 PM
Loose U joint djmac General FSJ Tech 1 09-26-2007 09:20 AM
SOA and driveshafts Woody Long Off-Road FSJ Tech 20 04-12-2006 04:13 AM
