Old 08-06-2012, 10:24 PM
6 0n 5.5 to 5 0n 5.5
79 j-10 what does it take to convert to a 5 0n 5.5 lug pattern on front axle d44, on the top of my head i forgot and i am to lazy with the heat to do research right now thanks
Old 08-06-2012, 11:34 PM
manimal's Avatar
manimal manimal is offline
I think its just knuckles outwards from a ford f100/150/bronco with a D44 front axle.
-Lance
Originally Posted by REDONE
Bring some wet-naps. I'm gonna lick everything you butt doesn't touch!!!!
Heck Yeah, I am an equal opportunity offender today and think we should all get bent.
Old 08-07-2012, 05:41 AM
addicted's Avatar
addicted addicted is offline
Big Meanie
Yep. The knuckles and everything bolted to them from a late '70's Ford with a solid front D44. The TTB 44's use different parts of some sort.
Originally posted by Ristow
i bet it was Simon....
Old 08-07-2012, 06:48 AM
TPICherokee's Avatar
IIRC, you don't even need knuckles out. You can just use the rotor off of a 1979 Ford F150, it should bolt right up to your existing calipers and spindles.
I took a set to a machine shop once (I had brand new rotors on a rig) and they redrilled them out to 5x5.5 (from 6x5.5) for $30 per rotor.
Old 08-07-2012, 09:57 AM
addicted's Avatar
Big Meanie
Ford used small bearing spindles. Jeep and GM used the big bearing as did Dodge on some of their stuff. The '75-'76 Jeep D44 used the small bearing spindles.
Old 08-07-2012, 10:41 AM
Casey's Avatar
Casey Casey is offline
Jeep Polygamist
Yep. Small bearing FSJ spindles w/Ford hubs and rotors. 4will has a Currie D44 front in his CJ that we changed to get the internal style hub. We had to do some parts scrounging, but once we found the correct spindles it was pretty easy.
I'll try and post some pics and parts list if I can find the list. Moving sucks.
1994 YJ
1986 Comanche
'57 FC-150
Carolina Full Size Jeep Club
www.cfsjc.com
www.patriotguard.org
"Go forth and be a tool".
Old 08-07-2012, 05:50 PM
78 Arizona Chief 78 Arizona Chief is offline
Wiley,
hey I may have those spindles and hubs since my buddy just converted his Ford to 8 lug and I think I kept the parts. I will look but it was the small bearing spindle and the hub.
Kevin
\'78 Cherokee Chief - 360/TH400/QT Front high pinion 44/ARB/4.10-1, Rear 44/ARB/4.10-1, SOA w/Alcan front springs, Alcan full-leaf (w/shackle eye flipped) rears, custom bumpers, Multi-mount Warn XD9000i, more money into her than I want to admit. Dad purhcased new, still have window sticker. 310,000 miles.
Old 08-07-2012, 06:06 PM
addicted's Avatar
Big Meanie
Originally Posted by 78 Arizona Chief
Wiley,
Kevin
You'll need the knuckles too. The spindles have a 5 lug pattern as well.
Old 08-07-2012, 09:35 PM
cool! i am thinking of replacing the rear of my j10 with a ford 9" out of a late 70's early 80's ford which will end up with 5 lug and then convert the front to 5 lug(this is going to be our pre-runner for mexico). I used to have all that info somewhere but i figured you guys would have it off hand and I was right thanks for the help! tim
Old 08-17-2012, 07:48 PM
78 arizona chief
did you have a chance to look for the front hub parts yet? thanks tim
Old 08-17-2012, 09:23 PM
talntar's Avatar
talntar talntar is offline
9's blong in hotrods not 4wheelers imho
85 gw 215k and still going
89 gw,free,almost legal
Old 08-18-2012, 09:09 PM
well i can tell you that my dana 44's can not handle the type of abuse we do to them and as far as a 9" belonging in a hot rod only look at the offroad race trucks we compete with and they are running a ford 9" in some manner or another. just saying, tim
Old 08-18-2012, 09:47 PM
talntar's Avatar
still my opinion
Old 08-19-2012, 12:22 AM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
IMHO a 9inch is the way to go for any kind of racing they have the two most important factors. They are light weight and strong, the only reason they arent in new fords anymore is because they take a bit more fuel to turn, since the pinion offset is greater than most axles, this is what gives them there strength.
Pierce,
77 J10 454, TH400, D20,
Old 08-19-2012, 11:43 AM
and you would be right.
