Old 02-08-2012, 01:42 PM
Poley's Avatar
Poley Poley is offline
Beadlocks VS. Rockrings?
Waht is the difference?? I know DUHHHH....
Fullsized Gets it DONE!!!!
Old 02-08-2012, 02:06 PM
orangecherokee's Avatar
rock rings are rim stiffeners. pretty much self explanatory. you mount the tire as you usually would on a rim.
Old 02-08-2012, 02:47 PM
derf's Avatar
derf derf is offline
360 AMC
Yep. A rock ring is just reinforcement (or in some cases, just cosmetic).
A bead lock has an inner flange that the inside of the tire bead rests against. The outer ring bolts on once the tire is in place and it clamps the bead in place. This "locks" the bead (hence "bead lock") and keeps the tire from unseating off the rim when you run low air pressure.
Try out my gear ratio calculator
Old 02-09-2012, 12:47 PM
Poley's Avatar
That is what I thought, ROck RIngs are basiclly for mall crawlers then.
I think I might invest in beadlocks.
Old 02-09-2012, 12:54 PM
cajun_lad's Avatar
cajun_lad cajun_lad is offline
Alot of people use both. The beadlocks keep the tire seated, and the rock rings keep the wheels from being damaged.
Joey
Jeep-Less
Old 02-09-2012, 02:47 PM
Poley's Avatar
Yes I understand that you will need an outer rock ring to bolt up to the inner beadlock. But just to weld on a rockring is GAY, just my opion.
Old 02-09-2012, 03:15 PM
j20brett's Avatar
j20brett j20brett is offline
Not exactly. Rim stiffener. I wish i would have invested in some back when i bought my wheels. Now i have a pratically worthless set of wheels with bead lips bent to heck and back from 2 years of hard wheeling. Dont write them off as for mall crawlers only.
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 02-09-2012, 09:10 PM
elbastardo elbastardo is offline
Interesting brett A fiew years back I ran A set of beadlocks on my XJ on 33s, I aired them down and did A hell of A hill climb (set fire to the weeds from the Xjs cat at the top). I bent to hell the pass side outer locks on the pass side. It smashed the the lock rings so hard that it caused seperation on the tires causing them to buldge, it basicly wasted 2 nearly new tires. On my newest set of pitbulls I went back to steel wheels W/O locks of any kind. I can reset A bead easily, just like we did years years back.
Old 02-10-2012, 08:36 AM
wat
Old 02-10-2012, 09:22 AM
ElkyRacer ElkyRacer is offline
wat
Probably talking about people using H1 beadlocks with rock rings.
Old 02-10-2012, 09:58 AM
derf's Avatar
360 AMC
wat
Maybe some people weld a rock ring onto the lock ring?
Old 02-10-2012, 10:53 AM
cajun_lad's Avatar
Yeah, I was
Joey
Jeep-Less
Old 02-11-2012, 08:05 AM
oh, gotcha
Hummer Beadlocks Again... Slick Willie Off-Road FSJ Tech 26 04-02-2012 07:07 AM
Beadlocks Sambo Off-Road FSJ Tech 14 06-20-2008 09:12 PM
H1 magnesium PITA beadlocks gwinn Off-Road FSJ Tech 10 01-05-2008 07:39 PM
Pulled the trigger on my tsl's and beadlocks today! KYJ10 Off-Road FSJ Tech 3 10-07-2004 04:48 AM
