Old 10-26-2011, 10:00 PM
Dirt Wag's Avatar
Dirt Wag Dirt Wag is offline
What did I break?
Here's the situation:
Stuck in mud like wet concrete - gas pedal to the floor - engine is really straining hard in 4LO to spin the wheels.
I hear a loud bang and see my left front wheel stop moving - I let off the gas
floor it again and everything turns like it should for a few seconds then it happens again. The same thing happened several more times that day.
At first I was sure something broke but if the strain is not too much everything seems to pull OK. It happens only when I go into some deep mud.
My first guess is the front Quick Lok (same as EZ Locker) - max recommended tire size is 32" and I'm running 37's - I think the teeth are sliding over each other. I pulled the diff. cover and there were a few very small metal shavings but no broken parts and everything looks OK.
Is it possible the t-case chain is jumping over the sprockets?
What do you guys think?
1985 GW, 360, 727, NP229, D44, AMC20, HEI, SOA/shackle flip 7" lift, Quick Lok locker rear, Aussie Locker front, 4.10 gears, 37 X 13.5 Interco SS-M16's, Warn Premium hubs, Tuff Stuff 12,000 LB winch, rear disc brakes === stripped down street legal off road toy
Old 10-26-2011, 10:32 PM
serehill serehill is offline
Gone,Never Forgotten.
Possible
It could be the locker disengaging & engaging. Especially unber load it would pop. I hate it when they do that. One wheel binds & the other wheels isn't getting any grip will cause that.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 10-26-2011, 11:29 PM
Shwagoneer's Avatar
Shwagoneer Shwagoneer is offline
i had this happen on my wag. similar scenario, 4lo, rpms maxed, climbing a steep sand hill. ended up being the cardan joint on the front shaft. the stabilizer ball busted. if you crawl under your rig, grab the front shaft and see if there is play left to right.
GARAGE - (empty)
SOLD - 1981 Wagoneer Limited AKA The Swagoneer
rebuilt AMC 360, TF 727, NP208, D44's
6" BJ's lift
BJ"s Sway bar disconnects
Rancho 9000 shocks
33/12.5/15 BFG A/t's
M/T Classic II Wheels
and alot of other goodies and doodads
http://i106.photobucket.com/albums/m...3/wagoneer.jpg
Old 10-27-2011, 02:08 PM
novacayne75's Avatar
novacayne75 novacayne75 is offline
sound to me like a broke locking hub or your locker is crap (most likely) the fix would be toss it and install an aussie or spartian locker. im not bashing your stuff but those lockers arent well known for holing up long due to soft metals.
78 j-truggy d60/14b,42's,tbi.
97 zj long armed and locked on 35's
03 quad cab 3500 ctd tow pig.
Old 10-27-2011, 04:42 PM
elbastardo elbastardo is offline
Sounds to me like A hub. I would start on the outside and work your way in, If it were the Tcase then it wouldnt stop 1 tire from turning, it would disengauge both. If your running A 44 front on 37s with A locker then the hub acts like A fuse, generaly the weakest link, and the easiest to repair. I might be wrong on my thinking but its definatly easier to start from the hub and work your way in.
When I was running A 10 bolt front on 38s up front, I had A spare set of hubs in the rig. There really easy to replace.
Old 10-27-2011, 05:22 PM
interesting
If it's poping & kept on working.
I've never seen a hub break & keep on working.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 10-27-2011, 05:35 PM
lunchbox1671's Avatar
lunchbox1671 lunchbox1671 is offline
I'll bet you sheered some teeth off of your front differential. Works fine till it gets to the section with the missing teeth....
1979 Jeep Cherokee Chief Sport 4 door N/T.
-AMC 360 with RV cam
-T-15A, Dana 20
-Dana 44's, 3.54's,
-32x11.50r16's
Old 10-27-2011, 05:40 PM
Hutcho's Avatar
Hutcho Hutcho is offline
what did i break?
Pride?
Formally known as "oilfieldtrash354"
"Grandpas" 1979 J-10 resto/mod-on hold for now
Preparing for Ouray 2013!!!!
Old 10-27-2011, 06:47 PM
i doubt that's his problem but i have seen a hub crack the drive gear and it just let it jump splines under load.
i had to make a puller to remove it cause it was jammed into the wheel hub.
Old 10-27-2011, 07:54 PM
I guess anything is possible
That doesn't exactly match what he's saying is happening. Just like broken teeth doesn't match. I've broke teeth & you'll know when that happens. & it doues drive ok after that. The only hub I ever broke did split & under load it out make a wierd sound but not a pop after it broke. You could just hear the splines stripping out more.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 10-28-2011, 02:17 AM
Sambo's Avatar
Sambo Sambo is offline
pull your hubs and report!
just a question,did you buy a new cross shaft when you put the "quick lock" in? this is the #1 problem with all lunchbox lockers!
77 chero DEAD.
lost oil pressure after 20 minute break in willysworker General FSJ Tech 20 03-17-2012 07:06 AM
How to break in gears? DrveJeepDrnkBeer Off-Road FSJ Tech 12 11-09-2008 07:07 PM
Getting my 258 rebuilt tomorow - any break in tips? Tripwire General FSJ Discussion 6 02-28-2007 09:18 AM
How do you break an axle? will e Off-Road FSJ Tech 20 10-08-2003 03:02 AM
Where to get break parts olin18 General FSJ Tech 2 02-04-2003 04:32 AM
