Old 01-09-2019, 05:54 PM
scout4bta's Avatar
scout4bta scout4bta is offline
New thermostat broke Tstat housing
Bought a new Tstat same brand as the old one. Cleaned every thing up, installed the new Tstat and preceded to tighten down the bolts. As I was alternately tightening down the bolts heard a "snap". Found a crack above the bolt flange on the drivers side.
On the new Tstat the formed edge on the outside was .068" high, the old one was .048". The depth of the counter bore in the manifold for the Tstat is about .035" deep. Seems an additional .020" is too much for the gasket to compensate for.
The Tstat brand is Fail-Safe manufactured by MotoRad, Hecho En Mexico.
Anyone else have this problem?
Found, the perfect Wagoneer to Dieselize, 1989 GW 360, 727, NP208
1980 IH Scout/4BTA/NV4500/Atlas 4.3/DYNO:172(HP),432(ft-lbs)25mpg
Old 01-09-2019, 06:33 PM
Tripwire's Avatar
Tripwire Tripwire is offline
its happened to me on baby jeep 2X.. on a OEM one and on a aftermarket.....luckly the local parts store had them in stock...NAPPA should be able to get you one, or i can send you one i have off a old rig..
Me thinks it was a thermal stress failure or a speck of grit between the mating surfaces
PM me
steve
Abort? Retry? Ignore? >
Old 01-09-2019, 08:33 PM
scout4bta's Avatar
PM me
steve
The Tstat housing is "pot" metal, very brittle. There was no grit on the gasket, the only stress was the extra .020" height of the new Tstat flange that was formed wrong.
Old 01-10-2019, 12:39 PM
When I worked parts counter (30 years ago!), broken thermostat housings were very common. The usual cause is misaligning the thermostat with the recess in the housing or manifold. This traps the edge of the stat on one edge and the housing breaks on that side. Not saying this was what you did, but it was a very common problem. The housing must set down tight on the gasket all the way around before you start tightening the bolts. If the stat flange is too thick, you could use an extra gasket.
Old 01-10-2019, 01:02 PM
scout4bta's Avatar
tgreese,
I was thinking of using 2 gaskets, but figured that it would give it a source for more leakage. So Im going get my money back on the new Tstat and reuse the old one.
I tested the old one and it does work, heated it in a pan of water and it does indeed start opening at 195℉, I thought I was doing my self a favor by getting a new one not knowing the history on the wagon/engine.
As far as the misalignment that was my first thought but after removing the Tstat housing the Tstat was fully seated in the counterbore.
If the old Tstat does ever fail I'll know what to look out for.
Old 01-10-2019, 03:04 PM
acct21's Avatar
acct21 acct21 is offline
I changed my T-stat a few years back, and have been ignoring a weeping leak at the T-stat flange for several months.
I pulled everything off, prepped the top of the intake with a Dremel and a wire wheel (same to the bottom of the T-stat housing). Then I put a thin layer of the Permatex water pump sealant on the intake, a thin smear on both sides of the Fel-Pro gasket, and a thin layer on the T-stat housing. Carefully put it all together, and hand-tightened the bolts until the Permatex just started to squish out. Waited 48 hours, pulled the bolts, put thread sealer on them, and tightened to spec.
That little extra smear of Permatex in there should hopefully have 'levelled' out the gasket and prevented any stress on the T-stat flange. So far it's been a couple of months, and absolutely no leak whatsoever.
thermostat housing - adaptor between housing & temp sender 18cherokee General FSJ Discussion 12 06-05-2015 04:45 PM
If you were to convert to diesel getlost4x4 Diesel Swaps 56 08-25-2012 05:33 PM
Thermostat housing seamus General FSJ Tech 3 07-29-2004 04:02 AM
thermostat housing/ vac lines Jeephopper General FSJ Tech 1 05-17-2004 12:52 PM
Thermostat Housing McBain General FSJ Tech 2 03-04-2002 11:10 AM
