Old 04-23-2019, 10:20 PM
Randyzzz's Avatar
Randyzzz Randyzzz is offline
J-Truck Mirror Placement
I am restoring a 1987 J-20. It has factory 3 point mirrors. I noticed that the passenger door mirror sits about 1"-2" closer to the front of the door than the drivers mirror, which is centered on the vent window. All the holes on both doors are painted not bare metal, so I'm figuring this is factory placement.
Using my best "Google-Fu", I did quite a bit of picture research, and it seems that there is a large percentage of J-trucks that have the passenger door mirror set further forward.
So...any consensus on this? Insider information? Reasoning? Or am I just being to OCD? No mater what, the passenger door holes will be welded up and mirror placement will be symmetrical, at least on mine.
Interested in your thoughts, or at least where your mirrors sit.
Randy S.
It's not what you Buy, it's what you Build.
1987 J20 SOLD
1966 Waggy SOLD
1970 Waggy SOLD
1982 Scrambler SOLD
1981 Scrambler - Current Project/Keeper
Old 04-24-2019, 08:00 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
my thoughts
could be a technical reason
could be difference in workers on assembly line
(each side prob installed by different worker as it went down the line.)
a friend has worked at dealerships for over 40 years
he has seen cars with different name badges on one side of a car
like a marquis logo on a crown vic,.... only on one side
GMC emblems on chevy trucks
the list goes on and on,......
just my ideas.
dave in NC
Old 04-24-2019, 09:40 AM
I've seen tri-pods mounted equal dist and not. I mount tri-pods legs so I have a clean view to the mirror w/o the vent window or window channel in the view. Also if your current view is obstructed, you can get different length 90* arms at any auto parts store. Better/cheaper than drilling new holes in the door.
Old 04-24-2019, 10:01 PM
Randyzzz's Avatar
Remembered I have several dealer brochures. All of them show the pass mirror further forward than the drivers, to varying degrees.
Randy S.
1987 J20 SOLD
1966 Waggy SOLD
1970 Waggy SOLD
1982 Scrambler SOLD
Old 04-25-2019, 04:02 AM
I got the Willys....
Could simply be about making it easier to see out of the passengers mirror.
1971 Gladiator
Old 04-25-2019, 02:11 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Bingo! That's all it is. If Dolly Parton is sitting next to you and your mirror is mounted half way back the door... you only see mountains, even if you're in Fl.
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
Old 04-26-2019, 02:19 PM
SOLSAKS's Avatar
jeepman,.....that was dang funny.
I never thought of the different position
being on purpose, due to obscured view.
I see what y'all are saying.
dave in NC
First post in a long time concerning my truck and trans swap kevinz General FSJ Tech 9 01-19-2016 09:47 PM
Finally got the truck operational 77 J10 General FSJ Discussion 13 07-19-2008 08:09 PM
Tested the tent, retread tires, and (nearly) used truck as lightning rod! BKCowGod General FSJ Discussion 8 06-23-2008 07:09 PM
Truck Avenger tuning tips? 78 Arizona Chief General FSJ Tech 27 10-25-2006 08:04 PM
FYI Truck Avenger Tuning specs... 78 Arizona Chief General FSJ Tech 17 10-05-2006 02:36 PM
