Old 04-11-2014, 06:25 PM
silvercert silvercert is offline
Headliner Cardboard sag
Got my headliner out to replace material... has a little sag in the cardboard. Any way to get that out? Would slight moister to it and a heavy object till dry get it out?
Daniel
I have some good news and some bad news. The good news is that I always allow each student one free pass in my classes. The bad news is that you have now used yours for this class. Doug
Old 04-11-2014, 06:43 PM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
Maybe you could get some of those long thin furring strips from the department store. Glue them & screw them to the top side, with big washers from the bottom side, then remove the screws.
There's enough room on top when it's installed to clear those 1/8" or 1/4" strips. Just don't do it where the cross braces are in the roof.
Never tried it, just a guess.
Ristow's Bunker
Old 04-12-2014, 11:58 AM
Mikeswagon's Avatar
Mikeswagon Mikeswagon is offline
get some velcro strips. There´s a lot of space between the cardboard and the rood, so you want to glue some fitting spacer to the roof and put the velcro on that.
89 Grand Wagoneer, work in progress
360, Edelbrock 1400, Performer Cam/Lifter/Manifold, Carter 4594 el. fuel pump, Skip White HEI
Old 04-14-2014, 09:09 PM
JAMESMOST JAMESMOST is offline
Curious as well. ,,sagging liner here,,,
Was thinking moisture and weights too....
78 Cherokee Chief (Buford) 360 4bbl th400 81k perfect unmolested Copper/Black , top end & trans rebuilt,,sweet survivor....
Old 04-15-2014, 12:13 PM
I replaced the material this weekend. With the new fabric the bulge is not as noticeable. It feels so much nicer now on the inside and looks great.
Daniel
Old 04-15-2014, 12:57 PM
Mine is warped not just sagging and no material,,, kinda vinyl laminate
New headliner (w/pics) and some rambling. Bobafett General FSJ Discussion 9 10-25-2011 03:29 PM
Replacing Headliner questions? 87 FSJ Frank G General FSJ Discussion 2 09-14-2011 08:20 PM
Honcho headliner color ? Honchov8 General FSJ Discussion 2 07-26-2010 04:43 PM
Roof Cardboard and Headliner... Brizio General FSJ Discussion 7 10-03-2008 06:20 AM
Headliner Options for cardboard replacment TBone89GW General FSJ Tech 1 03-30-2005 05:42 AM
