Old 04-26-2002, 05:26 AM
TJ - 78 Wag TJ - 78 Wag is offline
OK....
Let me start by telling you I am a novice at vehicle repair. However, tell me what the problem is... give me the Chilton's book, and I am pretty good at getting the thing up and running. So, instead of trying to diagnose where the problem is, I was hoping someone could tell me where to start looking.
Here's the problem....
When trying to start the Wag ('78) in the morning, it just cranks and cranks but won't fire. It has only begun doing this in the last week or so. It will finally start if i pump the s**t out of it ( like 15+ times ) or it won't because the battery dies. After it starts that initial time, the rest of the day is fine.
Any ideas?
Thanks - TJ
Old 04-26-2002, 05:33 AM
Don S's Avatar
Don S Don S is offline
Gone,But not Forgotten.
Cool
TJ - 78 Wag ......What kind of carb is your choke on??.... .......ds..
Sold our 1976 Wagoneer 406, MC4300, TH400, QT, TruTrac, 2" lift, 31x10.50s, duel Optimas,
It’s took us over 161 Colorado Mountain Passes, 3 Jeep Jamboree USAs & 2 Ouray Invasions from 1985 to 2010
ACRONYMS & ABBREVIATIONS HERE
Old 04-26-2002, 05:35 AM
fuel loss in the carb... I have to pump mine 7 seven times for the initial startup every morning..
I think it trickles away.. but I don't know where...
Todd
www.ttsfabworks.com
Old 04-26-2002, 05:48 AM
coolram coolram is offline
Now mine was just the opposite,in the morning pump 1 or 2 times to set the choke then she would start fine.Thru the day it would be pumping like TJ-78 and Riverbeast.I found my fuel pump was leaking around the body but not dripping on the ground(I guess the float bowl would drain back thru the pump).New fuel pump on(was replacing the starter when I found pump leaking)and problem solved.
\'95 Jimmy SLS 4 door 4wd 4.3 CPI/Auto<br />\'89 Grand Am LE 2 door<br />\'88 Grand Wagoneer sadly had to sell<br />\'92 CapriXR2 Turbo/Accel TFI coil<br />\'70 Monte Carlo SS454 107,000 original miles -sad to say but had to sell her<br />Had a \'79 Cherkee S 10 years ago and wish I still did
Old 04-26-2002, 11:16 AM
rigger rigger is offline
Try and retard your timing a little more . i had the same problem pumpit like crazy all i get is a broom and thats it i did a basic tfi coil upgrade and set up the timing to the manifold vacume and sound fires with 1/2 pump now every time. just a thought
yaya looks nice,but does she GO!?<br /><br />1981 cherokee lerado 360/727/208/d44/amc20 Wt<br />posi fnt & bck<br />.030\" overbore <br />crank shaved .010\" and line bored<br />balanced blueprinted<br />crane cam ,lifters<br />edelbrock preformer intake<br />edelbrock 650cfm four barrel carb<br />Tfi upgrade<br />3\" dynomax ultra flo exaust<br />custom lift springs <br />31\" bfg at\'s<br />CBR929 firblade<br />68 roadrunner 383 12.2 1/4 mile<br />original #\'s car
Old 04-26-2002, 02:33 PM
Careful34 Careful34 is offline
After you pump it a few times you're hold the petal down a inch or so while you're cranking it right?
89 Grand wagoneer<br />360, 727<br />w/ plow
