Old 05-08-2002, 12:14 PM
BOONIERAT BOONIERAT is offline
What position are the front shakles supposed to be in (vehicle stationary)? I decided to go look everything over in anticipation of the rest of my lift getting here, and noticed that my front shackles are pushed all the way forward against front of the frame. Is this correct? If not what position should I install them once I put the new springs on?
Thanks
1982 Wagoneer \"ODie\"<br /> 360 CID<br /> 727 TF <br /> 208 Transfer Case<br /> Rusty\'s 4\" four spring lift<br /> 31x10.50 Cooper STT (MUD)Tires<br /> 15x8 74 Blazer Ralley Wheels
Old 05-08-2002, 12:26 PM
rigger rigger is offline
no that is a bad sign they should be just past vertical toward the front
yaya looks nice,but does she GO!?<br /><br />1981 cherokee lerado 360/727/208/d44/amc20 Wt<br />posi fnt & bck<br />.030\" overbore <br />crank shaved .010\" and line bored<br />balanced blueprinted<br />crane cam ,lifters<br />edelbrock preformer intake<br />edelbrock 650cfm four barrel carb<br />Tfi upgrade<br />3\" dynomax ultra flo exaust<br />custom lift springs <br />31\" bfg at\'s<br />CBR929 firblade<br />68 roadrunner 383 12.2 1/4 mile<br />original #\'s car
Old 05-08-2002, 12:31 PM
Highsteel Highsteel is offline
I had the same problem you are describing..the front shackles were pushed totally forward. After much head scratching I found that the PO had moved the rear front spring hangers forward 2"! When my lift kit arrived I cut them off and moved them back to the right spot.. I found some cheap shackle extension in the rear floor board when I got the Cherokee and figure the PO moved the spring hangers to somehow compensate for the humongous shackle extensions..
So i guess the short answer to your question is when you are stationary your shackles should NOT be pushed forward more than about 30degrees..I can send you some pics of where they should be if you need..
John <br />78\' Cherokee Chief \"S\" <br />Holley 600/Performer intake<br />Rusty\'s 4\" lift 2\" bodylift<br />6.75 pounds of JB Weld psi.<br />BFG 33\"x12.50\" MT\'s<br />\"built\" Galaxy Ranger ham/cb<br /><a href=\"http://photos.yahoo.com/highsteel29\" target=\"_blank\">http://photos.yahoo.com/highsteel29</a>
Old 05-08-2002, 02:27 PM
Thanks guys,
I'm hoping that it's because the front springs are really shot. When I install the new springs I'll loosen them up and "hopefully" everything will be G to G and they will be back in the position they should be.
Thanks
Old 05-08-2002, 04:04 PM
nightflyers nightflyers is offline
When my front springs were shot, they were pushed forward, but I don't think they were that far.
Scott McMurtrie<br /><br />78 Cherokee WT<br />360/T-18/Dana 20<br />38\" Super Swampers
Old 05-09-2002, 04:48 PM
LHopper's Avatar
LHopper LHopper is offline
When I installed my lift only 2 1/2 inch. my front shakles moved about 2 inches forward which also moved the front wheels foward, but they look centered?? My lift springs came with the truck from the PO, so I`m not sure if they are the correct ones, but they do work.Good luck.
78cherokee360 4b carb. auto tob.400q/t D44 BFG 33`s w/2.5 lift w/added lowrange,TFI upgrade, and cat free
Old 05-10-2002, 12:18 AM
Here is shackle position with 4" Skyjacker springs:
Todd
www.ttsfabworks.com
