Old 10-02-2020, 12:39 PM
What do you guys use for Leaf spring clamps?
I am going to open up my rear leaf spring pack (stock) here in a couple weeks to add a helper spring. I expect to have to cut the stock clamp(s) off. I see some at Napa, Amazon, and Fleabay but some of them just look like 2 long grade 5 bolts through 2 mild steel straps. I expect to need about 6 of them (3 per spring pack). Do you guys just buy some on Amazon? Anything in particular that I should look for other than a 2.5" width?
Old 10-06-2020, 08:45 PM
DarkMonohue's Avatar
Shakes hands with danger
Glad you asked. I'm going to need to deal with this too sooner or later.
I miss the days when most decent-sized towns had a spring shop with two old guys who'd been there since they got back from Korea.
Old 10-07-2020, 07:48 AM
facts. I asked a buddy that just rearched his own 'Burb front springs and he said he was able to open the stock clamps, bend his springs, re-assemble, and re-use the stock clamps. I have not looked at my springs/clamps yet to see if that will work for me, but unless someone has another idea, I am going to attempt the same. If the clamp fails (I break it), I will figure out what to do after that.
Old 10-07-2020, 08:24 AM
I bought some clamps from an off road shop many moons ago. I think they were made by Rancho. Are they still around?
Old 10-07-2020, 11:33 AM
Kris's Avatar
Kris Kris is offline
Ive been using these for years. They don’t last forever but they’re cheap and easy.
https://www.summitracing.com/parts/slf-00250
At under $6 a pair you can keep extras around.
k.
89 Waggy
AX-15 swap info threads...
http://www.ifsja.org/forums/vb/showthread.php?t=83102
http://www.ifsja.org/forums/vb/showthread.php?t=97262
http://www.ifsja.org/forums/vb/showthread.php?t=104163
Theres more but that should get you started
Originally Posted by JeepinPete
-If it wasn't for bad luck, you wouldn't have any luck at all-
Old 10-08-2020, 10:45 AM
I have several J20 spring sets that have stainless steel straps very much like standard hose clamps. The important difference between the two is that the spring straps did not tighten with a worm. I believe these straps were also used on the HD suspension option for the Cherokee.
Resistance is not futile yet.
Old 10-08-2020, 05:29 PM
Jeep Doctor
I got mine from a local spring shop that's been run by the same guys since they got back from the Korean War; they were only a few bucks each back in the day, but they look like the ones in this link:
https://www.amazon.com/inch-Axle-LEA.../dp/B0084HA1GY
Old 10-30-2020, 08:57 AM
Originally Posted by Kris
Ive been using these for years. They dont last forever but they’re cheap and easy.
k.
Been running these on a 77 Wag for 17 years.
Thanks Hell Creek! Spring issue resolved/Old Iron Guys Listen up 1jeep4me General FSJ Tech 17 01-19-2012 04:22 PM
J10 spring mount q's... grand_wag_85 General FSJ Tech 4 04-10-2006 01:13 PM
Where to find leaf spring clamps paddyp General FSJ Tech 6 05-14-2004 12:33 AM
Anybody Try This Lift for pre-'75 Wags? Kimbrough General FSJ Tech 10 01-21-2002 07:24 AM
(TOM) Article on Leaf Spring that may be interesting to some. Joker's '88 GW Suspension and Steering 0 10-28-2001 01:38 AM
