Old 03-24-2004, 02:22 AM
ryphil ryphil is offline
Question
If I remove the belt to my smog pump, whats the worst that can happen? It started making an ugly rattling noise and I think its toast. But other than to get through emmisions, is it critical?
RyPhil<br /><br />1986 GW DD BJ\'s 4\" lift and she\'s gotta nice rack!<br /><br />1953 Glasspar G2 in pieces in the back yard but used to be my DD<br /><br />And now a 2004 Mazda3. Its got air conditioning. I know all you folks in AZ are jealous!
Old 03-24-2004, 02:26 AM
89grand's Avatar
89grand 89grand is offline
Resident ***hole
My belt is off right now, has been for over a year. I have to test mine next month so I'll put another belt on it just to take the test, then I'll cut it off again. It won't cause you any problem, all it does is inject air into the exhaust. Mine was starting to make a little noise too.
[ March 24, 2004, 08:29 AM: Message edited by: 89grand ]
Steve
1989 Black Grand Wagoneer, BJ's 4" lift, ProComp ES3000's
31x10.5x15 BFG AT KO's,MSD 6A,TFI upgrade,360,727,229,2.72 gears.
2006 Dodge Magnum R/T
2000 Jeep Wrangler
1988 Cadillac Brougham
1966 Dodge Monaco 500 383
1965 Pontiac Tempest 326
Old 03-24-2004, 02:40 AM
brad_fsj10's Avatar
brad_fsj10 brad_fsj10 is offline
If you still also have the cat. converter you may end up fouling that. The injected air keeps the burn process going to reduce carbon and soot (the very things that will plug up a cat).
Brad Smith
79 J20
360/NV4500
D44/D60/3.31s
past rigs -
86 J10
80 J10
79 Chief
Old 03-24-2004, 03:34 AM
DjD DjD is offline
My belt is off also. I passed inspection without it, but for a "technicality" low-mileage-driver reason.
I doubt it will kill your cat. The way I understand it, the pump increases the availability of additional oxygen (O2) molecules, in the cat, to combine with the bad CO molecules to turn it into ok CO2 molecules. The bad CO doesn't stay in the cat to clog it, it just comes out as bad CO.
If your engine is running so bad as to pump ridiculous amounts of HC, and possibly CO, into the cat, then I understand that could kill it. But then, in this case, it wouldn’t matter if your pump was working or not.
Don't know if it's a fact, but my manifold and cat line check valves seemed to degrade without the air being pumped through them. Or, maybe it was just time for them to die. You might want to keep an eye on them. You don't want those hot exhaust gases, from the manifold, being directed toward you brake fluid reservoir. Ask me how I know!
\'90 GW - Stock<br /><br />Planned modifications - Something to replace the duct tape that holds the cruise control module under the dash.
Old 03-24-2004, 04:06 AM
Originally posted by DjD:
Ask me how I know!
How do you know?
Old 03-24-2004, 04:57 AM
carrotman carrotman is offline
When the old pump seized up, the belt started smoking so I disconnected it. The eagle-eyed emissions guy spotted the missing belt, but a new pump was less than $50.
76 Chief, T18, 3.54, HEI, Carter AFB.
Old 03-24-2004, 05:55 AM
DjD DjD is offline
Since you asked.
http://www.ifsja.org/cgi-bin/ubbcgi/...c;f=2;t=012483
Old 03-24-2004, 07:38 AM
****. I guess I better keep an eye on it then...
