Old 06-26-2004, 11:48 AM
rstep's Avatar
rstep rstep is offline
any inputs to were to mount a duel system clean, i wanted to keep them under the hood with out making an already crowded bay worse
77 Cherokee 401/400 trans,Holley on edelbrock performer,PT 1339
d44s,detriot rear ,diff guards front and rear
Fabbed front and rear bumpers,Tire carrier
33"BFG KM2's on black spokes
Tadrack
Interior upgraded,Durango console, custom gauge panel,bucket seats
Soa,with 1" shackle up front
Hood vents
Old 06-26-2004, 02:48 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
You can buy or fab a drop in box to put right around/behind where your windshield washer tank fits.
Old 06-26-2004, 04:45 PM
Slim's Avatar
Slim Slim is offline
i removed my rad overflow ,, and relocated my windshield washer bottle ,,,,
77 Cherokee chief ,360 cid,quadra-trac,chopped /bobbed 12" , 8point cage, front exo ,d60frt 14bolt rear ,38.5x14.5x16.5 on beadlocks ,frt & RR winch,OBA ,SOA,shackle flip rear
** Island Rock Crawlers**
4WDABC Member
BCWF Member
Old 06-26-2004, 08:03 PM
imported_Big Red's Avatar
imported_Big Red imported_Big Red is offline
rstep, IRBOB did and awesome setup. I helped him install dual batteries and it looked factory! Rstep we need to get together when I get back from Iraq and hook up with Tadsal and have lunch or something!
IRBOB's dual batteries
1979 Cherokee WT, 360 4 barrel T18, Dana 20 twin-stick, SOA with a RB Shackle Flip, 4.27s, Hydroboost brakes, TFI upgrade, J-10 Rear axle w/rear Caddy disc brakes and 37" MTRs
Old 06-27-2004, 12:37 AM
rstep's Avatar
that's the set up i wanted to see got it already built for some one else did you have any tire rub. i built the unit a month ago but waiting to install then see how well it works
no prob. getting together also want to run the back side of the fort to gate 7, Zulu also from the area and we were talking about this yesterday so sounds great keep us up a return date
Tadrack
Hood vents
Old 06-27-2004, 12:38 AM
rstep's Avatar
big red that reply was for you thanks
Tadrack
Hood vents
Old 08-21-2004, 11:12 AM
irbob's Avatar
irbob irbob is offline
Unfortunatly I didn't get any after pix posted with the batteries installed. It was a clean looking setup with no tire rub. I could have dropped them another 2 inches for more hood clearance. The intake snorkle went right in between the batteries after I moved the end bracket over a bit. It was sweet.
Bob
83 Wagoneer Brougham (Rolled) Woooof
83 Wagoneer Limited (Parts Rig) Woooof II
Old 08-21-2004, 01:52 PM
rstep's Avatar
Irbob,griff sent the pixs of the one he had and i beleive he said you made it,the set up I did was about the same left room on this on for the a/c lines but the rad support got trimmed a hair,thanks for the input
Tadrack
Hood vents
Old 08-21-2004, 02:52 PM
PlumCrazy's Avatar
PlumCrazy PlumCrazy is offline
360 AMC
Location: Just S. of Branson (in Beautiful Razorback Country)
where did you get an isolator for the charging of the batteries?
My license plate says "Crazy" not stupid
*STATUS Down as a summer project*
Old 08-21-2004, 05:36 PM
Plum, just my two cents but I wouldn't use an isolator. They will always send juice to the weakest battery. Most of the time this is a good thing but I like to be able to control which battery(or both) gets what and when. I used two rebuildable 200A relays run via toggles switches and idiot lights to show easily which batteries are in/out of the loop.
Isolators are an option for sure but just not my preference but if you want one I've got a used one and it's yours for the postage.
Email me if you want it.
Old 08-22-2004, 02:49 AM
J20 project's Avatar
If you follow the link in my sig line, there is a pic of my dual system. Worked out pretty nice w/ big honkin cables between.
J20
BP Drivetrain...........
775-537-7918
Old 08-22-2004, 03:10 AM
drives mopars drives mopars is offline
i ran an 80 amp cont use solanoid on mine
use radios on 1 car on the other battery
93 dodge diesel 89 360 grd waggie<br />ham call kk6dm,want 4bt w/p pump
Old 08-22-2004, 11:04 AM
fulmetal fulmetal is offline
Its been so long I forget what was there originally but it went on the passenger side directly over the tire.Dropped in a box that holds two optimas, a couple of soleniods and we were in business. Nice location
84 Grand Wag<br />360, soa, headers,custom rear shackle flip<br />35 MT\'s,Mobi on board welder,12V air, Winch <br />\"and the to do list grows daily\"
Old 08-22-2004, 02:49 PM
zulu zulu is offline
i have the fenderwell that rstep. it was put in a couple of weeks ago. all three of my 4x4 have dual batterys. the j-20 has a isalotor from checkers that i like. the international travelall has a solonid that kicks in when i turn the key to start this thing, but when the key is off i can run all my accessories off of the 2nd battery and i dont have to worry about draining the starting battery. i have been leaning towards the solonid system for the cherokee. still thinking that over. all of the trucks have a aux fuze block that i run the acc off. dont have to worry about draining the starting battery. will keep you informed on the progress.
77 cherokee s,360, mild cam, headers,3.54s dana 44 turbo 400 p/txfer case,conti 33x12.50x15 9000lbs warn winch<br /><br />78 j-20 original owner, 401+0.30,t-18, dana 20 4:10 gears,8274 warn winch ,<br /><br /> 70 international travelall, the beast, big and ugly, made out of steel<br /><br />ernie
