Old 01-18-2020, 05:25 PM
76j10build 76j10build is offline
Adding a sway bar
I would like to add a sway bar to my J10, which didn't come with one. I don't think the spring plates have sway bar mounts.
1. Do I have to get the plates with mounts, or are there other alternatives?
2. Will my frame have holes for the bushing mounts?
I appreciate any help anyone could provide. I am putting on new front springs in the next few days, so if I have to switch the plates I'd like to do it now...
Old 01-18-2020, 11:16 PM
asphaltrockdweller's Avatar
The frame on a 76 that did not come with a factory sway bar will need to have a mount welded to the frame. You will also have to find a 76+ sway bar, spring plates, sway bar U-Mount, Bolts, connecting link, and the special studs that that hold it in place.
If you have a lift kit, you will need extended connecting links for it.
I have two 76 Waggy's, and one came with a sway bar, and the other did not.
My first Wagoneer is the one that came without.
After driving my Chuchua Waggy with, I was sold!
My yellow Wagoneer handled so much better on the road with the sway bar.
Here is a picture of the mount I had to add to the frame;
You could sawzall or gring a factory mount from a junkyard, but I just welded some C channel in there and tapped out two holes to mount the bar.
These are the spring plates you will need from a donor Wag:
Old 01-19-2020, 02:37 PM
Thanks for that information. I will try to start gathering up the parts.
I posted in the want ads to see if anyone has any of the parts, hopefully I hear back from someone. There aren't many of these in the salvage yards around me.
Old 01-22-2020, 02:32 PM
If you need any pictures of the factory mounts on the frame, and how I added mounts to the Waggy that did not come with a SB let me know?
I see you might of found everything you need in the wanted section.
Old 01-22-2020, 02:53 PM
MReese Wagonner's Avatar
MReese Wagonner MReese Wagonner is offline
So on this same subject has anyone installed a rear anti sway bar,? they are listed on one of the vendors
Old 01-22-2020, 11:16 PM
I have one that I pulled off of my 74 waggy, but that thing was destined to the scrap yard, so I have no idea how well it worked? I mean that Wagoneer was hashed, and it did not have a front bar anyways.
So I do plan to install it on one of my 76's later on how ever. I have pictures of it installed (mainly so I can remember how to put on another Jeep later.
But this should be in a new thread on "rear sway bars".
Old 01-23-2020, 04:19 PM
I *think* I can see what you did fairly well from the pictures you posted. I will be attempting to do the same thing. The one thing I may need is to know the distance to the frame mounts out from some fixed point so I can properly locate them.
Old 03-12-2020, 11:40 AM
asphaltrockdweller, is there a chance you could give me the a reference for the location of the sway bar mount on your frame? Also - does anyone know where to get the extended sway bar end links - is there something I can get at my local parts store?
Lastly - is there any benefit to having a track bar on the front? I want this thing to be very well mannered ON road, and if a track bar helps, I will see what it takes to install one.
I have access to the bar, but would have to fab up all the mounting stuff, as my truck did not have one originally.
I am trying to get the vehicle as well mannered on road as is possible, despite a small lift and larger tires. Any advice is welcome.
front sway bar fsj454 General FSJ Tech 0 12-01-2016 08:10 PM
Removing Studs from Sway Bar Dog Bones to Replace Bushings 88sunroof General FSJ Tech 0 08-24-2013 06:46 PM
Adding a rear sway bar to a truck for towing. How hard? Is it worth it? derf General FSJ Tech 19 11-29-2011 11:58 AM
Adding a sway bar? Schlagger General FSJ Tech 13 04-12-2011 01:19 PM
Dana 60 Spring Plates with Sway Bar Mounts viscacha Off-Road FSJ Tech 16 03-24-2005 05:20 AM
