Old 08-03-2009, 12:04 PM
seventynine's Avatar
Intermittent wipers on an older FSJ?
My '77 Chief doesn't have intermittent wipers and I'm pretty sure it wasn't an option in '77. Can you pull the switch and module out of a later FSJ and swap it in?
I've done that on one of my '79s and it works great...just not sure if there is anything different about the wiring on the earlier ones?
Thanks,
Dean
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
'13 FLSTN Softail Deluxe
Old 08-03-2009, 12:58 PM
chrisnsarah's Avatar
Yes you can, but I've never done it.
Years ago, I installed one of those JC Whitney intermittent setups in my '75. It worked great and it was not a hassle to install. The instructions tell you to cut into your harness, but I made an adapter to the existing switch, so I didn't have to butcher the harness.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
Old 08-03-2009, 01:12 PM
woodybeone woodybeone is offline
I'm sure you will still have to tap into the wiring. It won't be a unplug-plug in.
I built a control box (similar to the JC Whimpy)and tapped into a 70's wag once. Also worked great.
Romans 8:28
Brian Ray
"If everyone's against you it means your absolutely wrong.....or absolutely right "
Old 08-03-2009, 01:20 PM
Mikel's Avatar
Mikel Mikel is offline
My wipers work intermittently... Does that count?
1969 M715 6x6
1963 J300 Swivel frame
Old 08-03-2009, 01:39 PM
I'm familiar with that option also....seems to be a common FSJ problem.
My '77 works fine though...
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
Old 08-03-2009, 01:41 PM
drduckman's Avatar
drduckman drduckman is offline
Is there such a thing as intermittent rear window?
Tom
80 Cherokee Laredo WT 360/TF727/NP208 , HEI, True Duals w/Cherry Bombs.
Old 08-03-2009, 01:45 PM
Well I guess that is what I'm asking. For my '79 it was just swap the switch and plug the new harness in line and whala...intermittent wipers.
Didn't have to cut into anthing. The intermitent harness has the delay module on it and you just plug that into the plug that used to go into the old wiper switch and plug the other end into the new switch.
I pulled that stuff out of an '84 wag.
But...intermittent wipers were an option in '79 and they weren't in '77.
I guess I could just try it...you know pull the switch and harness off of my '79 and see if will work on the '77. I guess I'll look up in there and see if the wiper switch plug looks the same.
Dean
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
Old 08-03-2009, 01:46 PM
Ha...I've had that option too
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
