Old 01-27-2020, 04:10 PM
cameronb1988GW cameronb1988GW is offline
piggybacking on this dead thread.
where is the best place to tap in my new oil pressure test gauge on an amc 401? i figure i can pull the oil pressure sensor and hit it there but is there a spot on the top of the engine i can use so i don't have to lay down in the 4 quarts that blew past my filter gasket on Friday?
Old 01-27-2020, 08:01 PM
really no place but the pressure switch port,
Old 01-28-2020, 09:23 AM
MReese Wagonner's Avatar
MReese Wagonner MReese Wagonner is offline
at the factory oil pressure port,
mine already has the Pressure sensor and a Light Sensor
Old 01-28-2020, 10:38 AM
the sender can be removed from up top...
really no need to lay on the ground.
Old 01-28-2020, 02:40 PM
mwood65's Avatar
mwood65 mwood65 is offline
My stock 74' 258 runs at 20 psi at idle and 40 running down the road......
Good enough I guess.
What would it hurt to run 80 psi? I didn't think 80 psi was a bad thing necessarily.
Old 01-28-2020, 03:48 PM
No gonna blow out any seals etc but it if the oil is by-passing the filter...not so good.
Old 01-29-2020, 11:52 AM
Not a mod so I'm butting in here...
"Piggybacking" is a hijack. Better to start a new thread with an appropriate title. No reason not to start a new thread. You'll get more responses, and in the future, users can better search for the answers to your question.
Old 01-30-2020, 09:35 AM
okay, point taken lol. But yeah you are correct.
Holley Sniper install keeping the stock fuel system acct21 Fuel Injection 21 12-22-2019 01:57 PM
Yet another fuel gauge question Bkgw General FSJ Tech 6 06-26-2019 08:10 AM
Fuel gauge question socal_zj General FSJ Tech 5 02-18-2009 03:01 PM
Advice on new oil pressure gauge like Crazy Jeepmans 79_Limited General FSJ Tech 11 09-13-2004 08:09 AM
oil pressure gauge question shadowfax101 General FSJ Tech 3 08-19-2004 02:57 AM
