Old 04-15-2001, 02:40 AM
trickc's Avatar
trickc trickc is offline
what is the maximum amount of lift/tire size before a fsj will not fit into a standard 2 car garage?
after 4" suspension and 3" body lift with 35x12.50's is mine still going to be short enuf to get it into the garage? Just asking in advance.
74 cherokee nt,4"lift,
33's,lockers,winch,custom bumpers,what else is there?
304,th400,dana 20
3" body lift still in the box
35x12.50 wild country mud lugs (still in the garage)
www.trickjeep.freeservers.com
Old 04-15-2001, 03:40 AM
porkchop's Avatar
porkchop porkchop is offline
Master of B.S.
Mine doesn't fit in my garage! I have the SOA, AAL's, 3" body with 35's on 8" rims and it does not ift.
'67/'79 Wagoneer mix
"Red"
Check it out!
Mods, Mods, and more Mods! The end is no where in sight, but I am sure I am closer to the fork in the road.
Old 04-15-2001, 06:28 AM
WINGO WINGO is offline
Thumbs up
Take a look at your clearance now and add about 4" to 4.5".
3" for the body lift and 1" for the tires.
Why not give your garage a body lift?
Two courses of 12" block should do it!
WINGO
Vineland, NJ
USA
http://albums.photopoint.com/j/Thumb...100&Sequence=0
1984 GW 360
Rough Country/Heckethorn 2 1/4" AAL (actual lift)
Rough Country/Heckethorn Nitro 9000 Shocks
Performance Accesories 3 " Body Lift
31" X 10.5" Kelly MT
Soon to Have:
1- Rhino Grill
2- Alis-Chalmers Orange & Black Durabark exterior paint.
Old 04-15-2001, 06:40 AM
jeepbob jeepbob is offline
Jeep Idiot
You could always let the air out of the tires.
65 wag. 360/edelbrock rb4/t400/20 t-case/4:10 d27/d44 tracloc/onboard air/onboard 110v power(no inverter)/1999 Lincoln t.c.leather buckets/taurus ctr console/winch/33x12.50/tunes/water proof door pads
soon to have new motor/d44frt/d60r(4:10)welded diff/custom bumpers
see ya in da mud
Old 04-15-2001, 11:41 AM
GM Killer GM Killer is offline
<BLOCKQUOTE>quote:</font><HR>Originally posted by trickc:
<HR></BLOCKQUOTE>
I am running this set-up on my 79 wide track. I clear MY garage by about a 1/16th on an inch (seriously). Just let a little bit of the air out the tires to adjusty accordingly......
Matt~
79 Cherokee Cheif Wide Trac
Transplanted 401 w/ Edelbrock Performer Package
TH400 / Q-Trac
4" Skyjacker Softride lift
3 inch bodylift
35" Mud T/A's
____________________
99' Mustang Cobra -
320 HP F-body eater
93 Mustang Coupe 4 Cyl
Soon to have a transplanted 351w homemade twin turbo set-up
Old 04-15-2001, 10:30 PM
irbob's Avatar
irbob irbob is offline
Cool
I'm for lifting the garage.
My FSJeep Site &lt;----Click one of these----&gt; IFSJA Sticker
"Mystery Machine", 360, ,K&N, TFI, Custom Turbo II 2.5" single exaust, 999 Auto, NP229, F/Dana 44F, R/AMC 8 7/8", 32X11.5 Cooper Wildcat MT, Rancho 9000's, 2" blocks, 3" Performance Products Bodylift.
Old 04-15-2001, 10:45 PM
fulmetal fulmetal is offline
Thumbs up
Hey I am for lifting the garage. I could not convince my other have of the added cost bnut hey good luck to ya.
I got mine stuck the first time. Had to remove the roof rack and let the air out of the tires. That 3" body lift will be the killer. Good luck
84 Grand Wag
360, soa, headers,
33 bfg,on board welder,air
http://albums.photopoint.com/j/Album...a=11248759&f=0
Old 04-16-2001, 01:49 AM
trickc's Avatar
thanx for the replies,i have a garage attached to the house but will be building a detached 24 x 32 in the back yard and i am now convinced at least one row of cinder block should give me the clearance i need.
I don't intend to lift any higher or bigger tires this will be my maximum.(for this rig)
304,th400,dana 20
Old 04-16-2001, 03:19 AM
archiele
Posts: n/a
If you are building a new garage anyway, just install 12 foot doors! That would be the easiest and most cost effective way to do it.
Currently a 1965 Wagoneer
230 Tornado, Black 'D' style wheels
'88 Zuki
'75 Mercedes-Benz (wifies resto project)
http://homepage.mac.com/archiele/
Old 04-16-2001, 04:05 AM
tuckers89GW tuckers89GW is offline
I'd just put the lift on inside the garage, put it in 4low and punch it. Custom fit opening!!!!
Mike
<UL TYPE=SQUARE>
<LI>'89 GW
completely stock
<LI>'99 Windstar
under WARRANTY
<LI>see JEEP[/list]
