  #61
Old 11-13-2006, 01:25 AM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
360 AMC
here ya go yall.
just load up your 3 axis cnc mill.
indicate it,
and start making chips.
bada bing, bada boom.
square (and true) dshafts.
Old 11-13-2006, 01:27 AM
360 AMC
btw,
i made all 4 weld yokes to fit the 2" tube and for the 2 that will need to go on the 2.5" im just going to weld in a piece of 2" about 4" long and then slip over the 2.5" and weld it to the yoke also and plug weld it.
Old 11-13-2006, 09:28 AM
shadowjeep's Avatar
great idea, that should do the trick.
Rick C.
www.kymc.org
shadowjeep
2003 Chevy Silverado
Old 11-13-2006, 09:36 AM
rockjeep44's Avatar
The Advisor
That's awesome
Buggy Buildup
Originally Posted by welchct
Old 11-13-2006, 07:05 PM
learfxr's Avatar
learfxr learfxr is offline
so, how much to make a set for my YJ? I don't have the equipment to do the work
J10 Longbed-gone
89 YJ in work
95 ZJ Orvis
Old 11-13-2006, 07:13 PM
DAHoyle's Avatar
DAHoyle DAHoyle is offline
Question
Got started on mine yet?
67 M715
Old 11-14-2006, 01:44 AM
360 AMC
unfortunately i dont have the equipment either, luckily i have a good friend that happens to be a cnc programmer.
i made my front shaft tonight.
i welded a 3" piece of the 2" .250 wall into an end yoke.
i was able to get some weld on the inside also.
i then drilled some holes in my 2.5" for some plug welds.
slide it in and weld'er up.
no pic of the finished product, but let me tell you that .250 wall will go before the weld does.
Old 11-14-2006, 08:27 AM
shadowjeep's Avatar
thats awsome, now when can ya make some for the rest of us.
Rick C.
www.kymc.org
shadowjeep
Old 11-14-2006, 09:12 AM
BRUTUS's Avatar
BRUTUS BRUTUS is offline
DB... that is what I am talking about!
Old 11-14-2006, 10:07 AM
Dalton37's Avatar
Dalton37 Dalton37 is offline
Wow, this is a great thread. I will be using a lot if this information in my future projects. Subscribing.
Old 11-14-2006, 12:25 PM
learfxr's Avatar
I have some machinist friends back in Okla, but it's a 6 hour drive away. I may have to go see them over the holidays and show them this thread. My YJ is a custom creature using the Wagoneer TF727, NP208 and for now has the stock axles. It will be getting either a regeared AMC20 or possibly a GM14. Not sure on the 14 yet, a friend back in Okla has one setting under a van he said I could have.
J10 Longbed-gone
89 YJ in work
95 ZJ Orvis
Old 11-17-2006, 11:35 PM
360 AMC
hey man, i aim to please,
i put the front driveline in and it looks like it will work well. obviously im not getting this thing balanced, but i think that it will work ok.
Old 11-29-2006, 11:32 PM
Slick Willie's Avatar
Slick Willie Slick Willie is offline
So I may have missed it, but which end is going to the transfer case? 2.5" or 2"? And what about the rear?
-Will
'86 Wagoneer 360/727/Stak 3 speed/HP60/FF14/welded 4.10's/~3" Front Springs/Chevy 63's/42's/hummer beadlocks/topless/8 point cage/half doors
Originally Posted by rockjeep44
After this weekend chicks are gonna need suspenders to keep their panties up when I roll in
Old 11-30-2006, 12:43 AM
BRUTUS's Avatar
DB can put them either way because he is doing 1410's for every u-joint.
I am pretty sure you want the 2.5" end at the transfer case and the 2" end at the diff. Keeps grease in and water/grime/oil out the way I see it.
Old 11-30-2006, 12:44 AM
Brad W.'s Avatar
Brad W. Brad W. is offline
It doesn't really matter if it's 1410 on both ends, depends on the clearance with the exhaust, etc. I guess. Personally, i'd run the small tube on the axle side to help keep it out of the rocks, but it's really no different either way.
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
Old 11-30-2006, 03:10 PM
HotRodYJ's Avatar
HotRodYJ HotRodYJ is offline
One additional thing you might consider doing is to reinforce the open end of the larger outside tube with a 1" slice of 3" square like how the end of a hitch receiver is made. This protects againt splitting the tube down the weld. It's done on receiver hitchs for the very same reason, to prevent spliting the receiver tube. Like I did on the end of this receiver...
90 YJ,350 Chevy,700R4, NP231CHD with SS-SYE, SOA, HPD44 locked, 14B locked, 4 wheel disc,<br />38\" TSL/SX on H1 beadlocks
Old 11-30-2006, 04:45 PM
Brad W.'s Avatar
hey now, thats a good idea. I didn't think about the seam cracking.
Brad W.
m715 ex-firetruck
**project shelved**
Old 12-02-2006, 03:37 PM
Nice
Old 12-02-2006, 05:52 PM
360 AMC
like brutus said im gonna run the 2.5 on the tcase end to prevent (as much as i can) crap from getting in the shaft.
i like the idea of the 3" to strengthen it. might look into it. i dont think that it would cause too much problems draging across the rocks w/ the extra .25".
Old 10-06-2008, 07:24 AM
shimniok's Avatar
shimniok shimniok is offline
Addition from Jason:
I wanted to add that I am going to add some plastic wearstrip to the driveshaft the next time I take it off. I am looking at McMaster Carr PN: 7701T211 and then using some aluminum rivets or something to help hold them solid.
Thanks,
Jason
