Old 10-29-2003, 11:06 PM
scotty's Avatar
scotty scotty is offline
nope,should be 6. you only got 10 in a couple oddbal trannies like the t14
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 10-31-2003, 08:48 AM
netbear netbear is offline
OK folks, here's an update.
I found 10 min to unbox everything
and the Atlas that they sent me has
a female 23 spline input and they sent
me a heavy cast aluminum adaptor to bolt
the T18 to the Atlas along with a new T18
23 spline output shaft. I have no idea
how easy or hard the install of the new
output shaft will be. This is my first time
through this. I have to say everything
looks very nice. The 1350 CV flanges
on the F&R outputs are huge and the Atlas
is massive. It's like Christmas!
Next step for me is to drop the trans out
of my Jeep and put everything on the bench.
If anyone has experience swapping T18
output shafts, I'm open to any helpful
advise.
Can't wait to feel that 100-1 low-low with
the 401.
netbear
Old 10-31-2003, 12:13 PM
Stuka's Avatar
Stuka Stuka is offline
I hope you have some massive axles [img]smile.gif[/img]
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 10-31-2003, 01:08 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
advise.
the 401.
Sweet!
You stumped us all too. [img]tongue.gif[/img]
Wonder if that adaptor would let 'ya plunk on a NP205?
Old 10-31-2003, 01:09 PM
Elliott's Avatar
Cowboy Up
Oh yeah, emailed you some links and rebuild guide/diagrams.
Old 10-31-2003, 03:22 PM
scotty's Avatar
ahhhhh yes,makes sense now. [img]smile.gif[/img]
and yes,you could plunk on a dodge 205 with that adapter and taislahft. the dodge 205 is round pattern,and 23 spline input,just like the d300.
scotty
85 grand wagoneer
38" TSL SXs
Old 10-31-2003, 03:48 PM
Elliott,
Got the info. It will help me a lot.
Thanks for taking the time to get it
to me.
Stuka,
35 spline FF Dana 60s front and rear. I will
be using 1350 CV drive shafts front and rear
also. Anything can break but this stuff should
hold up to my mild driving style and 35-37"
tires.
netbear
Old 10-31-2003, 04:03 PM
Scotty,
Thanks for the NP205 (Dodge) info. I was
not aware they also use the 23 spline and
Dana 300 bolt pattern. Interesting...
I am always in awe of the info you guys
have. The main reason for me going with the
Atlas is that my rig needs to fit a multi-
purpose role where I can drive it for
extended highway trips and wheel it out
in Utah with my friends once a year.
The deep transfer case gearing allows
me to keep the highway rpms down under
3k even at 75 mph and be able to go slow
over rocks. I know there are other combos
that can do this but this is the one
I decided to go with.
netbear
Old 11-01-2003, 01:38 AM
Elliott's Avatar
Cowboy Up
What does it cost just for the T18 adaptor and output shaft from them?
I've got a spare T18 and if I build a dually it would be nice to swap in a NP205.
