Old 01-12-2020, 03:41 PM
waggin_around waggin_around is offline
Wheel specs for a 1980 with 4 inch lift
New new tires since the tread is coming off in chunks. Want to get new wheels too. What wheel size is needed for the front to clear the extended wheel hubs? Is there aftermarket hub covers that match if I get black wheels?
Old 01-13-2020, 11:02 AM
I don't understand the question?
The hubs don't have a lot to do with wheel selection other than the center opening needs to be large enough.
If you want fatter tires then wider wheels should be used but aren't mandatory.
Tire size plays an important factor in wheel selection.
Lots of info if you search on tires/wheels. Use google or bing and specify to search site:ifsja.org and it'll bring up tons of threads.
Old 01-13-2020, 12:09 PM
I
Old 01-31-2020, 10:27 AM
staying with stock rims
I think we are staying with the stock rims for now.
Purchased a Rough Country 3" lift with new front and rear springs.
Can I fit a 31 inch tire x 10.5 wide on stock rims safely? And will it rub leafspring when turning? Should I stick with 30 x 9.5 tire since stock rims?
And what about power loss. A 31" tire is 9.5% bigger than stock, that is quite a bit of gearing change.. Maybe another reason to get 30 inch tires instead? But I don't want them to look too small with the 3 inch lift..
thanks for any input.
Old 01-31-2020, 04:23 PM
rws31's Avatar
rws31 rws31 is offline
Almost all tires have a spec for "recommended" rim width. Simply look at the spec for the tire and see. I doubt a 31" tire will be out of "spec" for your stock rims and even if it close it won't hurt a thing.
I don't think a 31" tire will rub on the springs. I used to run 31's on my 82 and never had a rubbing issue. If you want to check and see, get the OD of your current tires and see how much room you have between the springs and tires when turned all the way. But don't forget you only gain 2" of radius on a 4" taller diameter tire.
As far as power goes, if you don't plan on any heavy hauling you'll be fine.
89 GW, 454, 700R4, 241C, 411's with posi's, 9" rearend, 2500 stall, lifted, and lots more to do.
1988 Ramcharger
1999 International 4700 Crew Cab 4X4, custom step side bed
2003 Durango 4x4
1982 CJ7 4 banger
2008 MB E320 Bluetec
Old 02-09-2020, 08:42 AM
TxJPs TxJPs is offline
Tires
I have the stock 7inch wide wheels and have been researching this because i want to go 33s. I believe 31s are not a problem but when going to 33s it really gets to be a small tire choice but i have found a few. Evem a couple 35s. As far as rubbing i think your fine but it really depends on if your doing full flexing. I think i need a 3 inch lift to flext all the way and fit tires.
Old 02-09-2020, 01:06 PM
asphaltrockdweller's Avatar
With only 3" lift use a 31" tire on your factory rims.
A lot of us do that EXACT thing and it is just fine.
What do you plan to do with the Jeep?
That should be your first concern. Is it mainly going to be a street everyday driver?
Or is it going to be an offroad only Jeep?
Adding tire size adds unsprung wheel weight, which affects your brakes, and everything else in the front end.
Once that happens, plan on doing more modifications to your front end, and lots more expense.
Drive shaft with 6 inch lift icedgotti General FSJ Tech 24 11-01-2010 06:08 PM
4 inch lift vs a 6 inch lift HD_JEEP General FSJ Discussion 7 03-09-2010 01:03 PM
1 inch lift shackle. Mex in the city General FSJ Tech 4 10-02-2009 01:29 AM
35's with 2 inch lift? kamikaze4x4nj Off-Road FSJ Tech 7 02-02-2007 11:59 AM
6 inch suspension lift and 3 inch body lift and trimming.. what size tires? magic2979 Off-Road FSJ Tech 14 01-20-2005 10:52 AM
