Old 01-02-2020, 05:34 PM
spitzer72 spitzer72 is offline
'89 GW oil pump repair
So, I ordered an oil pump repair kit and new housing from Team Grand Wagoneer. The new plungers that came with the repair kit get stuck right away putting them in the housing. The one from the old housing will slide right in. Should I just use the old one, or tap a new one into the hole? I don't want to get it stuck in there... Thanks
Old 01-02-2020, 05:53 PM
babywag babywag is online now
big red flag on quality there imho...
the plunger needs to slide freely in the bore.
I have always just refurbished oem covers.
Many not cool stories about aftermarket covers.
Old 01-10-2020, 10:38 AM
gophman's Avatar
gophman gophman is offline
Tbh as long as the original cover is useable (you would be surprised how badly the oil pump bore can look and still make good oil pressure) I would use it over a new one any day.
69 Waggy Stalls When Warm kodyharrell General FSJ Tech 11 09-30-2009 11:07 AM
Fuel Pump - Fool Pump scantar General FSJ Tech 2 04-07-2008 08:43 PM
double pumper on AMC supercopjason General FSJ Tech 34 07-31-2006 07:54 AM
OIL PUMP REPAIR KIT jeepers General FSJ Tech 2 01-29-2006 11:33 AM
Help / Vapor Lock Issue key General FSJ Tech 9 04-09-2004 10:54 AM
