  #41
Old 01-14-2020, 11:41 PM
FleetFox FleetFox is offline
I will take some pics of the setup i put on this weekend for the shift mechanism. Yours looks like mine, and mine does not match the Manual picture either. No spring in the U bracket,
You could pull the cotter pin out and remove the linkage. Then "click" the U bracket thru the gears to visualize the geometry.
Other than the jumped fuses, that box looks pretty clean. Buy a box of fuses and see how fast they blow. Then start tracing circuits.
Meine zwei pfennig...
Fleet Fox
Old 01-14-2020, 11:47 PM
Yellow wire is kickdown for trans. From trans solenoid on side of TH400 to neutral safety switch at base of steering column in cab. Orange is dash light for 4WD as mentioned earlier. Trans case top to dash cluster.
It does look like an earlier model fuse box. I had a 76 CJ with glass fuses, but the 79 I had was the plastic buss fuses. Perhaps export models were shipped with the earlier versions?
Fleet Fox
Old 01-15-2020, 12:57 PM
wincher's Avatar
wincher wincher is offline
Originally Posted by babywag
Cluster light bulb for QT e-drive iirc for 56
Ah, the emergency drive indicator switch in the transfer case
thanks
79 chief 360amc
02 wj 4.7HO Overland
Old 01-15-2020, 01:13 PM
wincher's Avatar
Hi friends what is wrong:
imgur com. choose foto from harddisc - the foto is on imgur
copy link, open the yellow insert image button , enter the link of the imgur pic....
and it is only a little white symbol in the frame, and no foto..
https://imgur.com/dY7H4bthttps://imgur.com/dY7H4bt
79 chief 360amc
Old 01-15-2020, 01:18 PM
wincher's Avatar
Fleet Fox
yes on the kickdown switch near the gas pedal are 2 yellow and a pink wire.
have their end in the nowhere probably
It is a 78 model and 78 were glas fuses. - mentioned earlier
79 chief 360amc
Old 01-15-2020, 01:33 PM
wincher's Avatar
Fleet Fox
Fine! the linkage is at least not "botched" . for once
unfortunatelly the jeep parks i a clean hall over the winter.
I have no garage to park them at home so far.
Have to built on in spring/sommer
the hall is no garage where i can work on the car.
There are other cars stored.
Therefore I can only do theortical work in the meantime
79 chief 360amc
Old 01-15-2020, 01:42 PM
wincher's Avatar
Chief
[IMG]https://imgur.com/2mBXaow[[IMG]
79 chief 360amc
Old 01-15-2020, 01:53 PM
when doing pics need to do "[IMG]"https://i.imgur.com/2mBXaow"[/IMG]" in brackets after link
minus the quotes those are just there so the forum will show them in this post
Also, use a resized image link or messes up forum formatting for viewers on smaller screens.
When copying the imgur link add a lower case L right before .jpg and the pic will be resized.
so say link is i.imgur.com/2mBXaow.jpg = 2mBXaowl.jpg
Old 01-19-2020, 07:55 AM
wincher's Avatar
Test.... thanks Tony for the instruction.
79 chief 360amc
Old 01-20-2020, 09:23 PM
Shift linkage from 1979 with TH400. Hope this helps>
[/url]0120201734a by
0120201734 by [url=https://www.flickr.com/photos/90577957@N07/]
Fleet Fox
Old 01-21-2020, 12:54 PM
wincher's Avatar
Fleet Fox
Thank yo Fleet Fox
79 chief 360amc
Old 01-21-2020, 09:51 PM
Bitte Schon!
Old 02-06-2020, 01:13 PM
wincher's Avatar
primary jets
79 chief 360amc
Old 02-06-2020, 01:15 PM
wincher's Avatar
secondary
https://i.imgur.com/nWy26vkl.jpg?1
79 chief 360amc
Old 02-06-2020, 01:17 PM
wincher's Avatar
rod
The setting of my carter 9637SA
79 chief 360amc
Old 02-06-2020, 01:24 PM
wincher's Avatar
different type or name of the jets?
79 chief 360amc
Old 02-10-2020, 10:53 AM
wincher's Avatar
carburetor setting
Now Im "between the devil and the deep blue sea" with my carb.
(Hope this phrase is right..)
I dont know my rod size and type. an Anybody decrypt the number on the rod? mikes carburetor parts cant do it.
Stock for the carb is 70x47 and orange springs.
the used jets are one step leaner with .95 main and .92 secondary.
I cant find carter parts in germany.
only edelbrock e.g. by edelbrock dot eu. Or other shops
In the 1406 ede calibration chart the 70x47 seams very lean, but the chart is with .92 main (#10)
Cant find a chart like this for the carter 625cfm
The 70x47 is not a part of the 1406 calibration kit.
I want only buy new rods and piston springs, and jets if neccesarry.
And a seal kit
Who can help?
regards.
79 chief 360amc
Old 02-11-2020, 02:38 PM
wincher's Avatar
Hi, I hope I have learned something about carburetors..
Thanks to mikes carburetor parts!
the stock setting for the 9637 is:
cruise.98-70=28
power98-47=51
My current setting is
cruise:95-68=27
power: 95-55=40
But I dont have a clue what to do.
Is this to lean for power? Should I change the rods?
Maybe I built the carb together, and drive some miles in the spring and check the color of the sparks.
Or do some checks in the garage with the old engine exhaust tester (lamda probe).
79 chief 360amc
Old 02-11-2020, 02:55 PM
Another method is to install a wide band oxygen sensor and gauge. That will tell you how it's running.
I wish I had more carb knowledge for you but I always just ran a stocker on mine until I went EFI.
79 Cherokee Chief
Old 02-16-2020, 12:32 PM
wincher's Avatar
a 4bbl was an Option for the Chief
In the 571 pages manual jeep engines from Mopar i have read something about the AFB for the 360amc
Nobody here who has a Carter AFB in his chief?
I will order a repair kit and the stock rods an jets for the AFB and give this a try.
Thanks to mikes carburetor parts for the support
79 chief 360amc
76 Chief 360/auto bolt into an 80 J10? FMSINC General FSJ Tech 14 02-17-2016 04:05 PM
1979 Jeep Cherokee Chief backfires Brody93 General FSJ Tech 9 01-23-2012 09:37 PM
4.0 swap in a 1979 Chief Pullie General FSJ Tech 25 10-28-2011 06:51 AM
Difference between chief and chief "s"? rentalrider General FSJ Discussion 2 04-22-2011 03:33 PM
1979 Baby blue Chief...SAW YOU TODAY! PlasticBoob General FSJ Discussion 0 04-17-2008 08:45 PM
