Old 07-16-2019, 03:44 PM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Tailgate hinges have some adjustment room at both ends.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 07-17-2019, 06:02 PM
SJTD SJTD is offline
Yep. Hinge to body bolts give you left/right adjustment and in/out of the bottom of the tailgate.
Hinge to tailgate bolts give you left/right tilt and up/down. Maybe some left/right movement also.
The pic looks like you need to loosen the hinge to body bolts and shift the whole shebang to the left. You have to loosen the bolts that clamp the springs tool.
Sic friatur crustulum
Old 08-22-2019, 08:25 PM
Driftwood's Avatar
Originally Posted by Driftwood
I salvaged a matching set of door locks and tailgate window switch. Had a key made for them. Excitedly, I insert the new key into the tailgate switch, turn it expecting window movement and ........NOTHING
I turn the key the other way.......NOTHING
I inspect the tailgate window safety switch, turn the key manically left and right......NOTHING....No glass movement.
The rear window works fine with the dash mounted switch.
So now I will completely disassemble everything AGAIN from the tailgate to access the window switch. I have another one somewhere in the garage.
Barnacles. Why me!?
Old 08-28-2019, 07:54 PM
SlowGear's Avatar
SlowGear SlowGear is offline
I'm in the process of rebuilding a donor tailgate.
Pretty sure without this thread I would have re-used the motor without opening it up to inspect. Sure enough, it looked exactly like yours. After a quick trip to Lowes, it's good to go.
Mike
88 Grand Wagoneer
Bone stock - except the missing stuff
Old 08-28-2019, 09:50 PM
You are the Ansel Adams of post photos!
I dipped into my tailgate long enough to replace the switch (BJ's kit is AWESOME), and saved dealing with my worn out pins, worn out channels for another day. Thanks for posting what you did, will reference this when I want to finish the job.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 11-16-2019, 06:38 AM
Driftwood's Avatar
Great news. Prior to dissassembling the tailgate, I checked for power on the wire to the panel switch . My Digital multimeter revealed 0 VDC. I isolated the issue to the 30 amp fuse (circuit breaker?) in the fuse panel. So relieved I did not have dive back into the tailgate.
Old 11-16-2019, 10:12 AM
Driftwood's Avatar
I tried to post pics of my tailgate switch. I'll try again soon.
Old 11-16-2019, 12:53 PM
chubbinius's Avatar
Awesome, that has to be a relief! Hopefully it will be a quick replacement on that fuse.
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 11-16-2019, 05:29 PM
Is there a thread problem, or is it just me? I don't see any photos
Old 11-16-2019, 05:54 PM
I see beeg minuses.
Old 11-29-2019, 07:12 PM
Fury5's Avatar
Fury5 Fury5 is offline
Very sad. I can't see the pictures either.
Old 11-30-2019, 10:35 PM
Meeeee too. Minuses.
79 Cherokee Chief
Old 01-08-2020, 08:54 PM
GWNashville's Avatar
GWNashville GWNashville is offline
Good luck with everything!
Richard
GWNashville
Email:alexhanmusic@comcast.net
1989 Grand Wagoneer 360 c.i.
727 Transmission
Serehill Rear Glass and Fog Light Harness.
Old 02-08-2020, 10:09 PM
redwoody redwoody is offline
pics
Sorry Im not able to see these pics. any help thx
88 GW hei E-fuel pump 360
tailgate rust repair help? jeepdreamer General FSJ Tech 3 11-10-2009 06:48 PM
I need some help...tailgate window repair gone wrong YoungClayB General FSJ Tech 9 02-09-2008 02:39 PM
A few tailgate repair questions...with pics YoungClayB General FSJ Tech 4 01-14-2008 02:47 AM
How to get tailgate down first, then Tailgate Repair GrandWagonero General FSJ Tech 1 04-03-2006 07:51 AM
Tailgate rust (How hard to repair?) mtnbikerman General FSJ Tech 1 10-06-2003 03:38 AM
