Old 01-02-2020, 05:29 PM
CTGW CTGW is online now
87 GW wipers stopped working
Hey fellas,
So now when I turn on the wipers, I hear a single click but the wipers don't move. Not cool. Any suggestions on where to start?
Thanks!
1987 Grand Wagoneer
Old 01-02-2020, 05:35 PM
The wiring diagram and and a Volt meter.
Prolly the switch but did you check the fuse?
Old 01-02-2020, 05:48 PM
bypass the intermittent wiper module.
unplug wiring from module and hook wiring directly together.
if wipers work module took a dump(common).
can get a used replacement from an xj if it's bad.
they're not made new anymore.
Old 01-03-2020, 05:20 AM
Red face
Thanks, I'll give that a try. Where is the module located?
1987 Grand Wagoneer
Old 01-03-2020, 06:28 AM
Theodore Theodore is offline
It is just up under the dash to the left of the steering column. Remove the lower section of A/C ductwork that runs under the steering column, and it should be attached behind the dash with Velcro.
Old 01-03-2020, 10:59 AM
Ok, I bypassed the wiper module and wipers still didnt work. Where is the fuse for the wiper motor? Is there a relay?
Thanks,
Andy
1987 Grand Wagoneer
Old 01-03-2020, 12:21 PM
no relay, uses a circuit breaker lower left corner next to fuse panel.
Fog lights stopped working... puckettj General FSJ Tech 5 11-13-2013 12:31 PM
Windows and Mirrors stopped working... Eric S. General FSJ Tech 19 03-25-2012 09:53 AM
wipers quite working? seadog General FSJ Tech 1 04-01-2006 09:30 AM
turn signals stopped working jhanson General FSJ Tech 3 04-05-2004 05:09 PM
nuts, lights stopped working frozen General FSJ Tech 3 02-19-2003 07:05 PM
