05-07-2006, 03:23 PM
Rabble Rouser
D44 Front Bearing and Seal Kits
Anyone have a link to a combo package? I just needs the seals and bearings, for a front rebuild. Maybe some shims too..wouldn't hurt.
I saw Bj's carries a kit for the rear, but didn't see anything for de front.
Part Numbers Are Listed Below:
Originally Posted by Crazy_Jeepman
As far as Parts Houses are concerned, the switch from Small to Big bearing spindles happened in 76. However I have encountered Small Bearing spindles up to 79 over the years. With that being said I do not buy wheel bearings untill I know what spindles I am dealing with. Following part Numbers can be had in Premium brand name or can be had where the quality of the box exceeds the bearing inside it  Personally I would not waste my $$$$ on the cheap bearings.
Small-Bearing Spindle-Inner-Bearing Journal Size: 1.78"
Stub Axle Spindle Bearing Kit Part# BRGBK1 $15.99
Hub Lock Nut Kit Part# BK6301653 $15.99 Needed only if your old ones are bad
Inner Wheel Bearing & Race set Part# BRGBR37 $18.99
Outer Wheel Bearing & Race set Part# BRGBR35 $16.69
Seal Part# NOS24898 $ 4.99
Big-Bearing Spindle-Inner-Bearing Journal Size: 2.00"
Hub Lock Nut Kit Part# BK6301653 $15.99 Needed only if old ones are bad
Inner Wheel Bearing Part# BRG LM104949 $15.99
Inner Wheel Bearing Race Part# BRG JLM104910 $ 9.49
As you can see the only differance in the small and big bearing spindle is the inner bearing all the other parts are the same
Thanks Ryan,
Tad
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
05-07-2006, 10:48 PM
would a local Auto Zone carry these kind of parts??? I need to get new seals for my truck and was thinking about checking there.
J10 Longbed-gone
89 YJ in work
95 ZJ Orvis
05-08-2006, 04:29 AM
I got seals & bearings from Randys R&P when I did mine in 02. The bearings were Yukon and I forget the manufacturer for the seals. About $85 an axel. The seals for the front axel tubes were too small though so I took one of the old ones to Parts Plus to get the right ones. Not sure what to recommend. I would be tempted to buy them all local next time, starting at NAPA. Unless I lived in Montrose, that NAPA guy would never see me walk through his door.
05-08-2006, 06:39 AM
i dont think autozone would carry i couldnt find a stub shaft for a 44 in there and i even got on the guys parts computer to look for it
Jeepless
In to Turbo crap now
05-08-2006, 09:12 AM
Dexron Impaired
Gamber, keep us posted as to what you are able to find. I'm looking at the same thing myself as Tequilla's front diff has blown bearings.
05-08-2006, 09:32 AM
If you mean the front wheel bearings & seals, they are listed under disc brakes on BJs:
http://www.bjsoffroad.com/cartgenie/...pid=389&cid=10
Paul
1975 Wagoneer DD
05-09-2006, 02:05 AM
Autozone carries the front wheel bearings and seals
I bought Timken front outer wheel bearings over the counter. $12 for the pair.
05-09-2006, 04:44 AM
autozone carries all the parts.
SBK1 for the inner spindle kit.
set 45 for the outer bearing set
471271 -inner seal
lm104949-inner bearing
jlm104910-inner race
Thats for any big bearing d44 waggy/chevy
05-09-2006, 10:29 PM
Rabble Rouser
471271 -inner seal
Nice, recall what it cost? ball park. Are 78 D44 (not HD) big bearing?
yeah, i can't afford BJs, I need the cheaper alternative..
(pause)
heh.
05-09-2006, 10:57 PM
Delightfully Incompetent
(pause)
heh.
All 74 (with disk brakes) thru 91 FSJs would be considered big bearing. As I have read, since Chevy D44s and Jeep D44s have so much in common and use a lot of the same interchangable parts, the need to specify big or small bearing really only applies to Chevy D44s.
www.j10mike.com
09-19-2006, 08:00 PM
Rabble Rouser
suggesting this be added to archives
09-19-2006, 10:09 PM
LMAO We need to take a trip back Flint see if he can order the right parts LOL
Paul
Paul<br /> 78 J10/J20 (NoHurry)<br />front 44H/D, rear 60FF<br />TH400/Dana 20<br />33 gal. custom gas tank<br /> 93XJ 3.5 RE, 31\'s,<br />30 locked<br />Dana 44 lsd<br /> 69 Sunbeam Alpine GT
09-20-2006, 05:44 AM
Rabble Rouser
ok, so this got moved..is it going to be added to archives, added too, or reside forever here?
This info was for a 78, maybe we could add any corrections for different years ..
09-20-2006, 08:01 AM
that bearing info should work for any chevy/waggy dana44 and even 10-bolt 76+
09-20-2006, 08:08 AM
Rabble Rouser
excellent! I suppose it wouldn't hurt to check at the store the parts OD vs a measured ID of your tube, since they seem to vary, eh?
09-20-2006, 08:44 AM
tube diameter will not make a difference. lug count shouldnt make a difference either....
09-20-2006, 07:04 PM
Sloppy Shifter
09-21-2006, 12:06 AM
Rabble Rouser
those are Jeep part #'s? Awesome, thanks.
09-21-2006, 01:24 AM
Also, don't forget:
Spindle grease seal part# 22311
Ft axle U-joint part# 210-0297 (cause you're in there anyway)
'88 GW Fun Hog - Dragmasters 360 rebuild, MSD TFI upgrade, Rancho RS5K, Ranco add-a-leafs, 31 AT's
09-21-2006, 07:29 AM
Sloppy Shifter
Originally Posted by Mario_CA
Also, don't forget:
The Part Number I listed for the:
Includes the seal part# you have provided.
Along with the spindle bearing
Additional Contents:1 EA 711818
B2110
22311
W/87593 SLINGER
W/453903 THRUSTWASHER
Thread Tools |
Display Modes |
