Go Back   International Full Size Jeep Association > Events > Las Cruces
Old 10-18-2012, 11:37 PM
Blake Blake is offline
parts swap?
I have a stock 4 barrel intake manifold for an AMC V8 that Tad has dibs on.
I also have a pair of AMC V8 exhaust manifolds including good air tubes (bolts are free and not frozen up).
Other parts such as flex plates, emissions components, etc, etc, etc.
Anyone interested?
Old 10-19-2012, 05:22 PM
We have FSJ stuff too. More than I care to list but if you are hunting for something, post up - someone else in the group may just have it. I do have abundance of 360/T400 flex plates, otherwise we have stuff that fits bumper to bumper.
Old 10-19-2012, 10:06 PM
the original Honcho's Avatar
I could use a front drivers side sidemarker light and bezel for a '75 wagoneer and a front passengerside sidemarker light for a '91 Grand wagoneer. Any or both at a reasonable price would be great
1980 Jeep J-20
1979 Jeep J-10 Honcho
1991 Jeep Grand Wagoneer
Unknown
1968 Plymouth Satellite
1978 Camaro- back in action
Old 10-20-2012, 06:38 AM
I'll have to let someone else go for the intake.
Buddy has been unemployed for a few weeks, no spare cash and he's most likely heading out of state for a bit.
Old 10-20-2012, 11:16 AM
Heimeken's Avatar
Heimeken Heimeken is offline
Stuff I am looking for:
Working 727 Transmission
33" Tires and rims, 8 lug 16" or 17" rim diam.
Shocks for 2 or 3 inch lifted FSJ in good shape
CV driveshaft with 2" tube diameter any length
Heater housing in good shape
Radio antenna (just the whip) for 79
Stuff in my junk pile for sale:
Front wide-track bumper (the lightweight one)
360 Flywheel
A Couple of 401 flex plates
power steering pumps
Engine/transmission mid plate
sway bar
4" lift springs for rear axle (like new)
air cleaner housing
dana 44 spindles with surface rust
universal winch mount/plate
Various D44 and D60 Yokes (strap style)
Shackles, both stock and M715 style
Dana 60 rear axle for 79 and older (needs complete rebuild)
Dana 70HD axle from chevy(4.11, open,ready to run)
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Old 10-20-2012, 01:25 PM
I have 3 or 4 front 1310 cv shafts for an fsj.
What specifically are you looking for?
Old 10-20-2012, 02:38 PM
Heimeken's Avatar
FJS shafts cannot really be sleeved like the 2" ones can with a stock pipe to make as a backup that is why I am specifically looking for a 2" diameter shaft, CV with 1310 joints. I have plenty of FSJ front shafts also
78 J10 "Imoteb"
Old 10-20-2012, 08:41 PM
mcjeep80's Avatar
mcjeep80 mcjeep80 is offline
i have a few good heater housings. metal and fiberglass. which one you want? i also have the 727 that was in my jeep. it has been outside for the last 2 months. it was a fresh rebuild with a few goodies. b&m rebuild kit and transgo rv shift kit, bolt in sprag, 4 gear planetary set and a deep steel pan. $500 obo comes with a high stall converter and a lokar cable.
'80 WT.cherokee-tbi454/4l80/241c
welded rockwells/ PSC full hydro /3"body lift
front soa on 3" springs/inboarded 63s rear
42x15x16.5 TSLs on 8 bolt H-1s
'77 Honcho, 454/th400/div.205
3" body lift/3" of aal
35x12.5x16.5 thorn turds
DD/Tow rig, 2005 5.9 Cummins 3500 CC/LB
Old 10-20-2012, 09:34 PM
Heimeken's Avatar
mmm, wasn't planning on spending that much on a tranny... but let me think about it as this one seems well built. Is it the original 23 spline output?
As for the heater housing, pm me what you want for whatever is in the best condition.
Originally Posted by mcjeep80
i have a few good heater housings.....
78 J10 "Imoteb"
Old 10-21-2012, 12:53 AM
Michael's Avatar
Michael Michael is offline
Jaime, what do u want for the 4" rear springs?
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 10-21-2012, 01:48 AM
i have a few good heater housings. metal and fiberglass. which one you want? .
how much for a good metal heater housing? I busted the fiberglass one on the waggy when installing the 401.
Old 10-21-2012, 06:33 AM
Michael's Avatar
Is that Dana 60 offset Jaime?
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 10-21-2012, 06:39 AM
mcjeep80's Avatar
how about $20 for a heater housing. i have 2 metal ones and 2 good fiberglass ones. as for the tranny, make me an offer it is just siting there.
Old 10-21-2012, 10:24 AM
I'll take a metal one. thanks!
muscle to rhino swap miscellaneous parts brubakes General FSJ Tech 7 10-25-2009 11:36 AM
78 Waggy to J10 parts swap jimbos83j10 General FSJ Tech 10 10-13-2009 03:33 PM
Parts Swap Gambler68 Moab 3 02-15-2008 09:08 AM
82 waggy to 71 J body parts swap? cabz General FSJ Tech 3 06-24-2006 06:57 PM
J10- what parts can I swap from KYJ10 General FSJ Tech 13 05-16-2002 07:02 AM
