I have a freshly rebuild 360 in my 1991 Grand Wag. It runs great, but I've been noticing some pinging in certain scenarios.
It only seems to do it when the throttle is almost wide open and the revs are fairly high (above 2500-3000 would be my guess). At lower RPMs there is no pinging at all.
It has a Melling MTA1 (RV-style) cam but everything else is stock, down to the 2150 carb and distributor.
The vacuum advance is connected to ported vacuum.
The EVAP canister and EGR are both in place, but neither is connected. There is no other emissions stuff installed.
Timing is set to 10 degrees initial, with whatever that gives me as total (I will check this).
My understanding was that it would usually ping at low RPM/high load. Why would it be pinging at high RPM/high load, and what can I try to stop it?
