Old 10-22-2012, 01:31 AM
1966cv300 1966cv300 is offline
Unhappy Repair of GW wiper linkage
HELP!!!! This is my first JEEP!
I have a 1990 Jeep Grand Wagoneer 5.9 with AC that the wipers quit on. The wiper motor is good and works easily. I have found that the linkage from the wiper motor to the right (passenger side) came loose when the stud pulled out of the cross linkage near the right wiper arm. I have already removed the cluster, radio, heater/AC controls, plus some skin off both hands and I can see the hole where the stud came out. I read the articles about windshield wiper problems but have some questions as follows:
1. How do I remove the large painted outside special nuts (With 4 slots) that hold the wiper pivots to the body so that I can push them inside the car with the cross linkage still attached? I can't see any way to disconnect them from inside other than that. Is that the correct method?
2. I assume that a good welder can simply weld the stud back in place when the linkage is out or do you need to buy a new linkage assembly?
3. Before they quit, the wiper on the drivers side was hitting the pillar HARD. Is that adjusted only by repositioning the wipers on the outside pivot?
4. I haven't lowered the AC yet. Is that an absolute necessity? I have already removed the left side lower AC duct but can't see how the defroster ducts come out. Any pictures would be great.
Thanks, Bernard
Old 10-22-2012, 10:45 AM
Mine was under the cowl in front of the hood?
Old 10-22-2012, 04:12 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
The assembly is one piece. The nuts require a spanner wrench, but can be loosened with a screw driver, and some care, they are brass, so they will scuff, but will clean up rather easily.
You will need to find the part at a parts yard or from a member here, they do not fix well.
Hope this helps...
WH
Herbina 1987 Grand Wagoneer
Old 10-22-2012, 05:37 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Yep a screw driver and a hammer, be sure to protect the paint...BTW. You are gonna be hating life trying to pull out the linkage, its a whole lotta no fun
I have never heard of one breaking like this especially where you live, (lack of use). You better closely look at the problem and maybe you can get one from someone parting out a rig
All that being said, i did buy a used one off of evil bay. For future use
Trip
Abort? Retry? Ignore? >
Old 10-23-2012, 10:19 AM
2 people is the easy way to do the linkage. I just did mine on the eagle and using a string to pull them in place was easiest.
Getting to wiper linkage on '89 GW ICXC_NIKA General FSJ Discussion 14 12-20-2010 07:39 AM
WIPER LINKAGE DILEMNA 86j10 General FSJ Tech 1 03-24-2010 05:01 PM
windshield wiper linkage ?'s 86j10 General FSJ Tech 1 03-09-2010 08:04 PM
Windshield wiper linkage? kittentitz General FSJ Tech 2 10-31-2008 02:09 AM
Wiper linkage problem , Help gr8lite General FSJ Tech 2 09-19-2002 02:36 PM
