Old 11-27-2005, 04:30 PM
oldcj5guy oldcj5guy is offline
Tried to find this online and in archives. I give up and my jeep isn't here and I need to know now. What is the measurement from the center of the left leaf to center of right leaf on the front leafs? Trying to tack some spring perches for some other measurements. jeep is a GW
'86 grand wag - Under construction
'79 j10 - 350tbi, th400 dana 20
'84 cj7/yj Have the engine and tranny now M103A3 - Under construction
Old 11-27-2005, 04:48 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Should be around ~32.25" if I recall correctly...
aa
Old 11-28-2005, 12:46 AM
I just happen to be setting up another SOA for a FSJ here and I always double check these numbers.
32" on center.
I've gotten that number on all the FSJ axles I have done.
I'm sure if you are little off either way it's not going to be that big a deal.
Old 11-28-2005, 08:28 AM
Thanks guys. Saves me a lot of work. The axle I have will bolt direct. I was getting ready to grind off perches to prep for new ones.
Old 11-28-2005, 12:51 PM
grimgaunt grimgaunt is offline
Location: close enuff to Denver, but far enuff from the people
32 or 42 " ???
Old 11-28-2005, 12:56 PM
Ted Wendel Ted Wendel is offline
It's 32"
Old 11-28-2005, 01:02 PM
Originally posted by grimgaunt:
32 or 42 " ???
Hari, oldcj5guy was asking about front FSJ spring spacing.
