Old 09-27-2004, 02:31 PM
Zorm's Avatar
Zorm Zorm is offline
Smile
ok, is the above mentioned doable?
The axles are off an 81 J-10 and I have an 83 Cherokee, would they be a direct bolt in?
thanks for any info
83 Cherokee 4dr WT(axles) 4" lift, 351w, nv3550, NP208, installing soon
65 Corvair Corsa Convertible, 4 speed, 140 quad carb engine
71 F-250 Camper Special (in rewire stage)
HE guides my path, forgives me when I stray and lights my life.
Old 09-27-2004, 02:36 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Rear axle spring perches will have to be moved inwards. The frame on the J10 is wider.
Old 09-27-2004, 02:46 PM
Front will bolt right up, but that is really the same as what you have in there now. But for a gearing change the J10 pair would be better kept together.
Some one here makes and sells perches
Old 09-27-2004, 04:29 PM
Hey Tad would that be somebody everybody knows or does he just pop on here once in a while
Old 09-27-2004, 04:42 PM
goldhammer's Avatar
You would also want to think about the front fenders off of the J truck or a W/T Cherokee, and rear flares of some sort. The truck axles are wider than your N/T
Art
ASE Master Collision Tech
Old 09-27-2004, 07:50 PM
imported_Big Red's Avatar
imported_Big Red imported_Big Red is offline
I have a J10 axle on big red. Like crazy Jeepman said got to mount new spring perches. Yea someguy does make those perches. Hmmmmmm! I hear that his business partner and himself kinda know what they are talking about
1979 Cherokee WT, 360 4 barrel T18, Dana 20 twin-stick, SOA with a RB Shackle Flip, 4.27s, Hydroboost brakes, TFI upgrade, J-10 Rear axle w/rear Caddy disc brakes and 37" MTRs
Old 09-28-2004, 03:48 AM
Yea, sorry, missed that NT part at the start.
