Old 03-15-2003, 01:21 PM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
360 AMC
Any special tricks to removing the side glass in a 1980 Cherokee two door?
Old 03-15-2003, 01:29 PM
Big Rock?
Old 03-15-2003, 01:34 PM
Gwamp's Avatar
Gwamp Gwamp is offline
High Tech Redneck
sawzall!
Roll up on you like Eastwood...
Old 03-15-2003, 02:39 PM
Damage, Inc. Damage, Inc. is offline
Lube (silicone spray or WD-40) and some plastic-tip 'wedgies'. I've always made mine out of thin teflon. It's like a screwdriver on both ends, about 1/2" - 3/4" wide and about 10" long. You use it to pry the weatherstripping away, a bit at at time.
74 Cherokee
Old 03-15-2003, 02:40 PM
Use a wooden stick or plastic rod or handle. Work it in between the seal and the metal inside the truck. As you work it along, put a bit of pressure on the window and start working the seal loose, like you were taking a tire off of the rim. Good idea to have someone help, but I had no problems doing this myself. At some point, the window will be loose enough to come out. Remove it from the outside. It is a really easy job.
Old 03-15-2003, 03:33 PM
Rent-A-Cop Rent-A-Cop is offline
i used a 4ft cheater bar i dont recomend this approach if you want to reinstal the window.
Buford Beaucham<br /><br />\"There was a time when detention had you hangin by your thumbs in the dungeons, God I miss the screaming!\"<br /><br />1999 Dodge Ram 1500 4x4 318 with an auto tranny- Daily driver<br /><br />1983 Buick Regal T-Type Black,T-tops, looking for a 400 4bolt main SBC to drop in her<br /><br />1976 J10 Honcho(resto project) \"The Shootist\" a tribute to THE greatest actor who ever lived
Old 03-15-2003, 09:33 PM
I is way simple to remove, but you will loose the rubber gasket.
Simply take a box knife and cut the rubber at the center all the way around, **** thing will just about fall in at that point.
Takes about 43 seconds to get into a Cherokee with a pen knife.
Old 03-15-2003, 09:36 PM
Brown Bear's Avatar
Brown Bear Brown Bear is offline
Takes 2.2 seconds with a crowbar or a thick head, like Pete's
NathanielButts
IFSJA Member #18
RIP-USS Minnow-The three hour tour is over.
MacGuyver - 1985 Grand Wagoneer
TFI, Edel Intake, Holley 80457S (yeah, it's shiney), K8600, K&N, Taylor Wires, Ford HD springs, and way freakin' cooooooool
Old 03-16-2003, 01:54 AM
I don't know if either of you could get through the side window after it was broken, anyway!! [img]tongue.gif[/img] [img]tongue.gif[/img]
Old 03-16-2003, 01:58 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Originally posted by jeepguzzi:
</font><blockquote>quote:</font><hr />Originally posted by Brown Bear:
I don't know if either of you could get through the side window after it was broken, anyway!! [img]tongue.gif[/img] [img]tongue.gif[/img] </font>[/quote]Pretty sure I could toss the Stupid Bear through the opening. Of course if he did not make it all the way through the opening, would not bother me either!
Old 03-16-2003, 05:43 PM
The Wagprocrastinator's Avatar
The Wagprocrastinator The Wagprocrastinator is offline
Originally posted by Crazy_Jeepman:
</font><blockquote>quote:</font><hr />Originally posted by jeepguzzi:
I don't know if either of you could get through the side window after it was broken, anyway!! [img]tongue.gif[/img] [img]tongue.gif[/img] </font>[/quote]Pretty sure I could toss the Stupid Bear through the opening. Of course if he did not make it all the way through the opening, would not bother me either! </font>[/quote]You guys make me laugh!
Rick Laney
Jeepless
Old 03-16-2003, 05:47 PM
Brown Bear's Avatar
[Pretty sure I could toss the Stupid Bear through the opening. Of course if he did not make it all the way through the opening, would not bother me either!
Is that a fat joke?????? [img]smile.gif[/img]
NathanielButts
IFSJA Member #18
Old 03-16-2003, 11:33 PM
andy d andy d is offline
Shade Tree Shaman
uhhmn, on a wag all i did was to remove the trim and push it out from the inside. gasket and glass were fine.
\'88 gwag,pure stock
