Old 09-04-2016, 01:58 PM
AMC-COMMANDO's Avatar
AMC-COMMANDO AMC-COMMANDO is offline
V8 to auto trans question
Just curious if a 1984 360 would bolt up to a Turbo 400. Currently it is bolted up to a 727.
Old 09-04-2016, 03:26 PM
serehill serehill is offline
Gone,Never Forgotten.
yes
you would have to add a spacer/bushing in the crank. You can do it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 09-04-2016, 03:45 PM
Crank bolt pattern is different?
Old 09-04-2016, 04:42 PM
Uh
I put a 79 that had a th 400 in a 727 80 model with no problem I had to remove the bushing on mine. different flywheel bolted right up. I'm not an expert but I didn't have any issue bolt patterns was identical.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 09-04-2016, 06:41 PM
the hub of the T400 torque converter is smaller than the hub of the TC727 converter,which the AMC's were machined for. so a small bushing,looks like a cam bearing,was used in the jeep applications that used the T400 trans,which was thru the 1970's.
Old 09-06-2016, 06:47 PM
Where could I get that bearing?
changing trans from Auto to 4spd on 1987 J20 MFRPA General FSJ Tech 2 12-27-2010 02:23 PM
Auto trans from 83 Chief into a 79 J20 jeephabit3 General FSJ Tech 3 12-11-2010 07:21 PM
Auto trans (727) cajunKen General FSJ Tech 2 03-04-2007 10:17 PM
Auto Trans guru. Need ideas on temp help N2Jeeps General FSJ Tech 10 03-02-2007 09:53 AM
727, NP 229 Trans mount question 2ManyWagons General FSJ Tech 4 09-13-2006 10:15 AM
