Old 10-12-2016, 04:46 PM
scottmcfly scottmcfly is offline
Noob!
4WD Quick Question...is it working?
When I had the front of my 89 GW up on jack stands I spun one of the front wheels, the opposite wheel would turn. But-the drive shaft did not turn. Is this the way the 4WD works? As far as I know the TC is in 4WD.
Thank you!
89 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229
31" tires
Old 10-12-2016, 04:56 PM
If you lift one axle, turn a wheel and the other wheel turns opposite. That's the way an open differential works. Has nothing to do with the transfercase.
Old 10-13-2016, 12:30 AM
Mike D's Avatar
Mike D Mike D is offline
im confused
Lift front left and rear right .. try that again ...
64 Wagoneer 283 SBC
50 truck
63 J-200 Truck -- help bring home
Please, if you believe in the power of prayer, God and Jesus Christ... I beg you add my relationship with Heather Boyd to be reconciled to a new, stronger than ever, wonderful marriage ... to your prayer list and remember us daily.
Addendum:
And now that im getting Divorced .. i want to work on it , but no one else does -- ^ -- Heather, please leave your affair with Josh Smith and come back to the father of your children
Old 11-20-2016, 04:36 PM
Noob!
Thank you for your reply. Now I understand the way an open differential works, But... should the wheels be able to spin (while in the air) and the Driveshaft not move? I just want to make sure my 4WD works.
89 Grand Wagoneer
D44's front\rear
AMC 360
TF 727
NP 229
31" tires
Old 11-20-2016, 08:55 PM
BadRat's Avatar
BadRat BadRat is offline
The further up the drive line you go, the more tension will exist from various sources...
As a simple answer, with all 4 corners suspended, with an open diff, all wheels suspended, turning one wheel will simply turn the other wheel on the same axle in the opposite direction given path of least resistance...you're just spinning the axles via the spiders internal to the carrier.
Drop one wheel of the front axle to the ground, and provided your drive train is in neutral, then the grounded wheel will offer the most resistance, and turning the lifted wheel will force the ring/pinion to turn, turning the driveshaft.
None of which necessarily proves if your 4 wheel drive is actually working.
To do a test using jack stands, you'd have to have all 4 corners suspended, start it with the system engaged, and see what happens...
(Just make sure your vehicle is properly seated on the stands, and that ALL wheels are sufficiently off the ground)
Kurt; but you can call me anything you want, except late for dinner
1988 Jeep Grand Wagoneer
Hand me that doo-hickey wrench thing, and a beer
Old 11-21-2016, 06:23 AM
JeepJeepster JeepJeepster is offline
Ive never tried turning the driveshaft on our FSJ but, in my liberty with the 242 tcase I can turn the front driveshaft if the front wheels are off the ground and the tcase is in 2wd. When the tcase is in 4wd I cannot turn the front driveshaft with the front wheels off the ground and the rear wheels on the ground. Again, I cannot verify if this is true with the 229 but you could try it...
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 11-21-2016, 09:04 AM
Marineviper's Avatar
Marineviper Marineviper is offline
Go find the nearest snow and gun it in reverse and see if snow flies out the front. �� But in all seriousness, Mike D's advice is the best advice as it proves the front and rear are at least integrated while transmission is in neutral.
Open differentials are not the only thing that have opposite spinning tires, trutrac posi, electric, and air lockers will to. But that isn't important in your issue.
76 j10 short, 360 nailhead th400 D20, 3.54, 4" lift, 31" bfg ko2
HEI
CS130 105amp
Comp cam sk10-200-4
Edelbrock performer w/1406
Quick question on rear defroster Blake General FSJ Tech 3 01-15-2008 11:54 PM
Quick audio question xsonmyeyes General FSJ Discussion 18 08-31-2007 09:22 PM
Got a quick question on skid plates.... xsonmyeyes General FSJ Discussion 6 08-05-2007 05:39 PM
Quick heat riser question Heavy_Metal_Thunder_81 General FSJ Tech 14 06-14-2007 07:53 AM
Quick and easy question about lock-out hubs.... lharrell79 General FSJ Tech 3 06-10-2004 11:52 AM
