Old 12-08-2020, 01:04 PM
So after a few years and while staring at my grill (also I had nothing to do waiting for my engine bits to come back from the machinist):
1) I wanted more contrast between the gloss and background,
2) the cracks were getting worse,
3) and the chrome hoop that goes up into the hood looked terrible and was really bugging me.
So I bought a crusty grill from another member on here. It was from Michigan (I think?) so there was some decent corrosion but the price was right and I planned on painting it the same way as before anyway.
For anyone painting one of these pignose grills, there are basically 4 finishes on them. There is the dark silvery paint that goes on the background and behind the grill, there is the a chrome like super thin paint, a flat black on some of the chrome foil, and then the thick foil like chrome that is polished. On the grill I bought A LOT of the dark silvery paint and super thin chrome like paint was peeling off.
You can really see where it is peeling off on the back
Here you can see a ton of it was removed
So the first step (conducted in a hotel room on a business trip) was to polish the outer chrome strip and remove all the peeling finishes I could. To polish the chrome strip I used some 0000 steel wool and this metal polish I bought at the Pomona Swap Meet in the mid 90s. There are 2 spots on the grill where the chrome is damaged. I don't care about them since they sit behind my lights on my bumper. Here is one of those spots of damage
Here you can see after the outer chrome has been polished
I kept using some coarse steel wool, a razor, a pair of tweezers, and whatever else I needed to keep removing peeling finishes. I get it pretty well cleaned up and rinsed it off in my hotel shower. I am about 4 man hours into this grill at this point:
Next up was to fix all the cracks and re-enforce the weak spots. All these pignoses fail in the same place, the upper center support. It cracks, and then the chrome foil peels. There were about 6 different areas that I had to fiberglass over but the top center bracket was the worst. I cleaned the crack up with some 120 grit, the alcohol and this is how it looked. Notice it is cracked on the top AND bottom.
I used the tools I had on hand (hotel trash can filled with water) to push that crack shut and fiberglassed it together.
I only show the 2 spots on the top center bracket in these pictures, but there are about 5 other spots that needed fixing. Once the fiberglass had hardened, the grill felt MUCH more solid. It was pretty nuts how much of a difference it made.
Then I sanded the chrome I was planning to paint with 220 grit and used some body glaze to fill the cracks (every step included continuing to remove peeling finishes). You can see many of the little red blobs of areas I needed to fill.
Next, I sanded it all down with 220 grit, masked all the areas I wanted to leave chromed and got it ready for primer.
Here you can see there are 5 different areas on just the upper bar that needed filling. I will bet if you have an original pignose, you have little cracks in the same places. On the back of all these places there is fiberglass reinforcement. I am about 12 hours into this grill and my business trip is over.
That weekend I sprayed it with 1 coat of self etching primer, let it dry, then sprayed it with 2 heavy coats of sandable primer. Then I stuck it back on the shelf for a couple months waiting for another business trip where I could bring it with me.
Flash forward to about 3 weeks ago. Here is the grill after being blown off and brought back out.
You can see the cracks are pretty much gone. The filling worked! Wooo Hoo!
Spent a couple hours wet sanding it I think it was 400 grit? Might have been 600, though.
Then I re-masked and took it out to paint it. We had a day that was killed because someone in our group got the 'Rona so I found a place out in the hotel parking lot to spray the Rustoleum Painters Touch 2X Gloss black. I think I did 2 light coats and one thick coat. Gave it 8 hours in the warm'ish Novemeber Ontario CA sun.
I unmasked it and stuck it on the shelf again when I got home. I wanted the gloss black to be fully cured before I touched it again.
Last night, I took it down off the shelf, and re-masked again. The green tape is 1/4" masking tape I bought the first time I painted my grill. I masked everything I wanted to stay chrome or gloss black.
I spent a few hours trying to find the FLATTTEST black that would last. I did quite a bit of reading on flat black paints and ended up with this:
Here is how my grill ended up:
SUUUuuuper stoked on it!
Check out the contrast between the gloss and flat black:
Now, is it perfect? NOPE!!! but my truck is a turd and if the grill was too nice, it would stick out. It looks pretty darn good, though! I hope to install this on my truck sometime this week; those pictures will go on my build thread. All in all, probably about 30 man hours in this used grill. Probably a total of about $60 in paint, filler, and sand paper.
Old 12-08-2020, 03:45 PM
ALOT of work !!!
it payed off
looks great !!!
ready to see it on the fsj
I like the flat/gloss black combo
and the 401 emblem especially.
Old 12-08-2020, 05:18 PM
chubbinius's Avatar
Marc, that looks great. Definitely put the downtime of travel for work to good use!
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 12-09-2020, 10:46 AM
Tastefully done Marc. The 401 emblem makes it righteous.
That emblem also fits nicely on the rise in the hood.
Old 12-10-2020, 08:38 AM
I tell you something else that is righteous
those other emblems on that wagoneer in your photo fullsizejeep
wow.
Old 12-10-2020, 12:22 PM
Yeah it does, Dave! Looks great!!
Thank you, all! I'm hoping to start a resurgence of pignoses up in this !!!
Old 12-15-2020, 11:37 AM
letank's Avatar
letank letank is offline
Very gooooood idea on the fiberglass, I used marine epoxy, it cracked again, then JB weld over a larger area on both sides, it cracked again...
Old 12-15-2020, 11:46 AM
In the same place? That top middle bracket?
Old 12-15-2020, 03:00 PM
letank's Avatar
exactly, it was in a previous post on page 1, but I never detailled the damaged spot, here it is during the prep
Old 12-16-2020, 01:48 PM
letank's Avatar
here is the crack(s)
Old 12-27-2020, 01:15 PM
nograin's Avatar
nograin nograin is offline
best I can tell these are ABS.
The JB weld plastic epoxy and putty doesn't work well on ABS.
Yea I tried it too.
The best with ABS is chemically disolving and joining the cracks. Acetone works OK. Acetone mixed with scraps of ABS provides better filling.
I got lazy and simply used the ABS Pipe cement that I've had in the house (there was one vent stack with some ABS when I moved here).
Works very well except for the color.
I should have some photos of the repairs to the jeep's grill but can't find 'em right now.
Here's a couple of useful webspages:
http://nerfhaven.com/forums/topic/18...lding-plastic/
https://www.polyvance.com/identify.php
Found the pics and loaded a few up.
Grill_before_repair
Grill_with_ABS_Cement
Grill_with ABS_cement - Building this section up in stages.
Grill_1 year later_(2018)
The black line is visible from the front view. Important thing is that the repairs have held solid.
Suppose one of those chrome paint pens on the crack would hide it better.
I like the idea of SEM Colorcoat (for plastic) to paint the exposed white ABS.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 12-29-2020, 11:36 PM
Great! I hope my fiberglassing works as well as your ABS Pipe cement!
Old 12-30-2020, 08:27 PM
Full Size Jeeper's Avatar
(Rang to house keeping) NO NO NO, Come on in. I'am working on my grill for my 79 Cherokee. I promise, I don't even have all the necessary chemicals to cook meth with me on this particular business trip. Go check out my build thread on IFSJA if you think I'am a lair!
Old 01-06-2021, 07:37 PM
letank's Avatar
Thank you for the chemistry lesson.
This is a very good and proven point: acetone with piece of ABS or the matching plastic pieces works really well.... I had some time to practice on ta taillight lense some time ago... repairing the missing screw hole bit. It works perfectly.
Old 01-08-2021, 09:16 AM
Smile
Rang - I LOVE the hotel room work. AMAZING!
1984 GW
360
Comp 260H
Harland Sharp Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 07-22-2021, 03:50 PM
letank's Avatar
Got lazy too and used the plastic model glue that I had left over from a few light years ago... works well, I had multiple reasons to lean on the pignose and it has not cracked , yet...
Thank you
Old 09-21-2021, 12:12 AM
Mike D's Avatar
Mike D Mike D is offline
if you can
I had my Rhino grill powder coated white at a place that i was working at -- at the time --
Still looks great -- ill try to get a picture posted somewhere to share ...
64 Wagoneer 283 SBC
50 truck
63 J-200 Truck -- help bring home
Please, if you believe in the power of prayer, God and Jesus Christ... I beg you add my relationship with Heather Boyd to be reconciled to a new, stronger than ever, wonderful marriage ... to your prayer list and remember us daily.
Addendum:
And now that im getting Divorced .. i want to work on it , but no one else does -- ^ -- Heather, please leave your affair with Josh Smith and come back to the father of your children
types of paint? 68_Gladiator General FSJ Discussion 15 06-30-2011 07:57 PM
Weird paint fade lost1 General FSJ Discussion 0 04-18-2010 06:44 PM
What kind of Paint??? FireFro General FSJ Discussion 2 06-02-2008 08:52 AM
wanted wrangler paint code so i can paint my truck NCOfab General FSJ Discussion 0 03-08-2008 02:05 PM
brake fluid as a paint stripper????? will e General FSJ Tech 7 02-22-2003 12:18 PM
