Old 11-20-2008, 08:32 PM
Long&Low's Avatar
Long&Low Long&Low is offline
J Truck rear slider removal.
Ok, like the title says, is there any secrets, tips, how-tos in taking a rear sliding window out of a mid 80's j-truck (without the help of a BFH, or cutting the gasket).
Thanks.
Mike
Breakfast amounts to one live toad, I choke that mofo down, and I am rest assured that nothing worse will happen to me for the rest of the day.
___________________________
CJ truck project
'18 Jeep Renegade
'15 Jeep Cherokee
Old 11-20-2008, 08:34 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Yes, the gasket has a split in it. Find the split, seperate the sections and "unzip" it using a flat screwdriver. A lil teflon spray speeds things along.
Old 11-20-2008, 08:37 PM
Tornado230's Avatar
There is a seam on the outside of the gasket. Take something not too sharp and get in the seam. You can then "unlock" the weatherstrip. Do this all the way around. Get inside, push on the bottom of the window frame, remove the window from the gasket.
Old 11-20-2008, 08:40 PM
Long&Low's Avatar
hhuh, a seam, I'll have to look harder.
THANKS!
Is the seal re-usable in general?
CJ truck project
'18 Jeep Renegade
'15 Jeep Cherokee
Old 11-20-2008, 08:41 PM
Elliott's Avatar
Cowboy Up
Absolutely
