Old 10-29-2017, 06:25 AM
1969 dream wagon 1969 dream wagon is offline
First generation dash pics
I need pics of a fully loaded first generation j truck or wagoneer dash.(rear side so I can see stock fasteners) thanks in advance
Old 10-30-2017, 07:46 PM
j10jim's Avatar
j10jim j10jim is offline
I dont have any pics but I do have the full dash wiring harness for one. I swapped out the speedo, and all the wiring. Let me know if you want/need it. Make you a great deal
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 11-02-2017, 05:37 AM
Harness
What is the condition?
Thanks,
Matt
Old 11-02-2017, 07:27 PM
Kaiserjeeps's Avatar
Here you go Matt. I thought I would respond here instead of the PM. Maybe it will help someone else in the future also.
The speedo cluster and heater controls are held in with a spring loaded clip or clips. The trim ring is held in with the green speed nut. Same as the other side around the speaker.
The speaker is held by a metal bracket with hex screws and you can see that here.
The vent knobs are held by a metal retaining clip just like the brake hoses but a smaller version.
The ignition switch is a spring loaded switch that twists to unlock two small tabs in the bezel. A new one in the hand will show that well.
The headlight switch is held in with a small nut and bezel.
Hope that helps.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's and a 7
Old 11-03-2017, 09:56 AM
j10jim's Avatar
All stock condition. I will snap a couple of pics of the harness and stuff this weekend.
what dash fubar General FSJ Discussion 7 02-26-2016 01:39 PM
offroad dash pics? shadowjeep Off-Road FSJ Tech 18 05-25-2010 01:04 PM
Dash Pics jMedia General FSJ Discussion 2 03-03-2010 07:46 AM
Pics of dash without dash pad? toyjeep General FSJ Tech 8 09-28-2009 01:27 PM
Custom Dash Pics? Gearhead 1990 General FSJ Tech 17 03-26-2009 08:07 AM
