Old 10-27-2017, 06:50 PM
kgocj5 kgocj5 is offline
body lifts
i just bought a 2 inch body lift. is it a good idea to epoxy the pucks to the mount points? or is it not necessary?
1976 cherokee chief
1979 cj5
1989 4 door cherokee
2004 rubicon wrangler
Old 10-30-2017, 07:47 PM
j10jim's Avatar
j10jim j10jim is offline
I didn't. Seems to work just fine.
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 11-01-2017, 08:24 AM
Cecil14's Avatar
Cecil14 Cecil14 is offline
As long as your tighten the bolts correctly, they should never go anywhere.
I've had my BL on for about 10 years now, never had a problem.
aa
was just thinking a bout body lifts... motion vega General FSJ Discussion 0 03-10-2013 11:42 PM
Body Lifts EnigmaticEngineer General FSJ Tech 0 01-30-2010 11:07 PM
Body Lifts jimmy hat General FSJ Tech 4 08-11-2003 06:42 AM
Body Lifts...75-83, Why?! BigBadWag General FSJ Tech 6 05-28-2002 07:39 AM
well....I am gona put on a body lift.... Stuka General FSJ Tech 15 09-18-2001 03:03 AM
