Old 02-06-2012, 11:49 AM
dkmcgowan dkmcgowan is offline
1989 Jeep Grand Wagoneer, 2150, no power valve?
I have a 1989 Grand Wagoneer, and I have been fixing all the connections and hoses under the hood, and the last step is I cannot find the power valve...
I know exactly where it should be, in between the 2 idle mixture screws, but where it should be is a flat plate, nothing is damaged, and it is the plate without the nipple on it...
I have read that the older 2100 model use to work the power valve internally with no external vacuum hookup, but from what I can tell the 1989 Grand Wagoner should have a newer 2150, and that should have a nipple on the power valve...
It seems to be running fine, just curious about this. Is it possible a 1989 would have a 2150, that had an internally working power valve with no need to hook it up to vacuum?
David
Old 02-06-2012, 12:45 PM
Blake Blake is offline
Yes, anyone could have swapped anything in.
Post a pic of the carb. There are lots of pics of a 2150 in my Goofy Build Thread, link in my signature.
Old 02-06-2012, 01:01 PM
I will post up some pictures tonight... It looks just like yours exactly, except there is no nipple for the power valve... It's not capped or plugged, or broken, there is a stock OEM looking flat plate over it...
I passed emissions today, so that is good
David
Old 02-06-2012, 01:43 PM
I don't think you would be able to pass emissions if the power valve wasn't functioning - it would be way to rich.
I have pics of failed emissions reports in my build thread when I ran it through emissions with the PV hose incorrectly connected. Makes a big difference.
Old 02-06-2012, 02:10 PM
It also runs really well... I not only passed, but aced the test...
I think it's working, I really think this is a 2150 in an 89 wagoneer, with an internal power valve...
I am just looking to see if this was even possible in 1989
David
when I say possible, I am curious if this is the carb that actually came on this vehicle in 1989...
pictures will come tonight...
david
Old 02-07-2012, 08:59 AM
Here are some pics, some are blurry, but I included anyway to help identify the carb. I didn't see any serial number on it. I also included a few close up shots o the power valve cover, so you can see there is no nipple.
It's running ok, I passed emissions, I am just curious if this is the original carb, and why it doesn't match the vacuum diagrams I have seen. I did a bunch of searching last night, and I did find a couple of people talking about there being "some" 2150 carbs being built with internal power valves, but not many. Maybe I just got one of those?
Other than the power valve, every single thing else matched perfect with my 89 vacuum diagram and is all hooked up properly...
David
Old 02-07-2012, 09:09 AM
more pics
Old 02-07-2012, 09:14 AM
here are more pics, I could not attach anymore, so I linked to them...
http://dl.dropbox.com/u/61034888/201...-13-09_758.jpg
http://dl.dropbox.com/u/61034888/201...-13-20_744.jpg
http://dl.dropbox.com/u/61034888/201...-13-59_379.jpg
David
Old 02-07-2012, 10:01 AM
I don't think I saw the altitude compensator in the rear of the carb.
I don't think it's a 2150.
I think it's a 2100.
Ristow would know.
Old 02-07-2012, 11:04 AM
This is a better picture of the back of the carb
http://dl.dropbox.com/u/61034888/201...-13-47_993.jpg
I don't see the altitude compensator...
If this is a 2100, is there anyway that is what was stock on a 1989 grand wagoneer?
The PO didn't seem like someone who new enough to change out the carb...
David
Old 02-07-2012, 12:43 PM
rreed's Avatar
rreed rreed is offline
Looks like an older 2100, nice and clean though. I'll dig through my box of 21xx carbs as soon as I can and help give a hint. I think 1-2 of mine have the low profile power valve cover though I'm not sure that means it just doesn't have one. I don't know when they went from internal vacuum source to external nipple on the power valve.
47 Willys
75 CJ-5
81 Scrambler
96 ZJ
Power Valve & RV cam pushrod questions Rich88 General FSJ Tech 4 03-27-2011 06:06 PM
Power Valve? scotty1998 General FSJ Tech 5 10-16-2009 08:04 AM
Holley Power Valve and Jet Questions JohnIL General FSJ Tech 73 02-14-2008 09:29 AM
Faulty Power Valve Anteloper General FSJ Tech 4 07-04-2004 04:06 PM
