  #461
Old 01-16-2019, 08:27 AM
rockosocko's Avatar
rockosocko rockosocko is offline
Wow! haven't been here in a while.
...Looks like a great time!
My aunt had a Yellow Pantera back in the day (70's) along with a lime green 914. and Brother had a 70's Marauder with a Police interceptor motor. I think 3.73's ??
https://goo.gl/images/AFWBQA
(probably the only ferd that actually ran well in the family) VERY FAST!
But I was only around 7-9yrs old.
I DO remember that my sis-n-law's '70 monte would beat it off the line, but once it got rolling good, it was GONE!
Keep the pics coming! Gives me incentive to get going on stuff.
E
Old 05-21-2019, 08:37 AM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
After that last drag day and autocross of last year, the clutch was just about done. Not unexpected since it was pretty rough looking when I got it used. Replaced with a new stock Hellcat clutch.
Dust just from unbolting the bellhousing.
Flywheel still looks the same as when I installed it used.
You can see the thickness difference between the old and new disc.
Major difference in preload between old and new.
Yep, I know my PM box is full. Email me instead.
1983 Cherokee WT - IFS, trailing arm rear, full cage, Hemi, 6 speed, turbocharged - Autocross project
http://ifsja.org/forums/vb/showthread.php?t=127321
Old 05-21-2019, 08:44 AM
Ghinmi's Avatar
Super Moderator
Had a small winter project. Finally got my hands on a Majorette 1:64 Cherokee from Bulgaria ebay. Lowered, wheel swap, painted, added weight. I have a hot wheels drag strip with full timing system, it's one of my quicker modified cars.
Old 05-21-2019, 08:58 AM
Ghinmi's Avatar
Super Moderator
Winter updates to the Jeep were all electrical. Added a driveshaft speed sensor, electronic boost control, and a line lock. I mounted the switches in an old torched piston from my nitrous days.
Left switch is line lock arm, left button is line lock enable.
Right switch is launch control. If the switch is enabled, vehicle speed below 1 mph, and clutch in, the launch rev limiter is set, boost builder enabled, and line lock set. When either of those three conditions are broken, rev limiter releases, boost vs time starts, and line lock releases.
Right button is rolling antilag.
Excuse the mess.
Old 05-21-2019, 09:07 AM
Ghinmi's Avatar
Super Moderator
Went to the first test and tune of the year at US131 at the beginning of April. Quite a learning curve with the new launch strategy. Previously I was leaving at 6300 rpm with no boost and rolling the clutch out. Now I'm leaving at lower rpm on a 2 step on boost and ramping in boost down track. Still have to work on it but did get it to 1.5x sixty and 10.50 @ 133. Pretty pleased for the first time out. The tire is much happier than before.
Had to call it quits early because it developed a brake shake. Yep, drilled rotors that came with the front end kit failed.
Old 05-21-2019, 09:42 AM
Ghinmi's Avatar
Super Moderator
Was invited back to be on display during the Autocraft Custom Collision open house. Showed up a little early to swap out the radiator that had sprung an un-fixable leak. That removable front clip sure is convenient.
Old 05-21-2019, 12:22 PM
Ghinmi's Avatar
Super Moderator
Made a trip to Chicago and on the way back stopped at US12 Speed and Custom for some quick dyno pulls. Just made two at slightly different boost levels and called it good. 720 whp and 840 ft-lbs. Way more than expected.
https://youtu.be/Wm_1p0WZxbk
Night before. Good camping spot.
Without a doubt, my favorite car (truck) at US12.
Strapped down.
And my cruising buddy Eric.
Old 02-10-2020, 12:19 AM
How are things goin these days? Any shows? Any updates?
79 Cherokee Chief
Choptop Buildup Thread krek General FSJ Discussion 137 11-18-2018 07:04 AM
Build Thread sticky tgreening General FSJ Discussion 2 01-08-2010 09:13 AM
Making some progress on my Cherokee build Gearhead 1990 Off-Road FSJ Tech 62 10-29-2007 08:27 PM
Azusa off-road videos, pics, and Cherokee review PlasticBoob General FSJ Discussion 12 10-23-2007 05:48 PM
